[GRASS-user] how to derive polygons from text strings
Hello list,
I have a point feature layer with attributes for a text string (call it 'label') and the fontsize in map units (which are meters in my case). Is there a way in Grass to derive polygons from this input information which enclose the label strings when those are used to label the points? For those who know ArcMap: what I mean is exactly what happens when you save Annotations as Shapes in ArcCatalog: you get a polygon layer in which each text string has a polygon hull which fits the height and width, respectively.
best regards,
Uwe
AFIAK no*
It is more tricky than it might seem as exact dimensions depend not
only on font size but also on selected font (see monospace vs
condensed fonts), kerning, styling (bold, italics). Thus final size of
bonding box of a string is a product of all of its properties. Thus
the best option to get the size right is to ask the same rendering
engine to calculate exact dimensions as it will know the size it will
use.
* apart from one used for vector labelling in d.* modules, but that is
not exposed to the enduser. See D_get_text_box from display library.
Māris.
sestd., 2021. g. 18. dec., plkst. 18:50 — lietotājs Uwe Fischer
(<gisfisch@t-online.de>) rakstīja:
Hello list,
best regards,
Uwe
grass-user mailing list
grass-user@lists.osgeo.org
Hello Māris,
thanks a lot. That is hard tobacco for a user like me. What do you mean 'ask the same rendering engine'?
Is there a chance to get such boxes for a normal user or is it a case for a c++ programmer?
Mit freundlichen Grüßen,
UWE FISCHER
Ingenieurbüro Fischer
Esbecker Str. 8
31036 Eime
Tel.: 05182/8325
Mobil: 0172/8876934
Von: Maris Nartiss [mailto:maris.gis@gmail.com]
Gesendet: Montag, 20. Dezember 2021 08:25
An: Uwe Fischer <gisfisch@t-online.de>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Betreff: Re: [GRASS-user] how to derive polygons from text strings
AFIAK no*
It is more tricky than it might seem as exact dimensions depend not only on font size but also on selected font (see monospace vs condensed fonts), kerning, styling (bold, italics). Thus final size of bonding box of a string is a product of all of its properties. Thus the best option to get the size right is to ask the same rendering engine to calculate exact dimensions as it will know the size it will use.
* apart from one used for vector labelling in d.* modules, but that is not exposed to the enduser. See D_get_text_box from display library.
Māris.
Hello list,
best regards,
Uwe
pirmd., 2021. g. 20. dec., plkst. 11:29 — lietotājs Uwe Fischer
Hello Māris,
This depends on how you are planning to use those frames around text.
If as a background for a text, it might not fit well as the exact
width and height of text will depend on the rendering engine used to
draw text. Frames around text in ArcGIS work only as long as text
itself is rendered by ArcGIS. Try to draw text in frames made by
ArcGIS with QGIS and most likely you will not see a perfect fit even
if the same font is in use.
You can always go back to scripting. If selected font is monospace,
calculations are easy, if not monospace, it will be hard to get it
right. Thus digging into C code seems to be the best bet.
UWE FISCHER
Māris.
