I am trying to use some vector operations in GRASS.
I can not understand what I am missing but it happens to me that the vector commands works on all the vector data instead of working only in the active region. I am wrong or is it so, and if so is there in GRASS the possibility to create a new vector data cropping the original one on the active region?
Thanks in advance for help
Silvia
the active region?
One solution that I have found to crop vectors to the region:
1)Crate a region box with v.in.region
2)Crop with v.overlay operator=and
Pablo.
Quer ver seus e-mails de todas as contas num lugar só? Junte todas elas no Hotmail.
Thank you Pablo,
unfortunately my vector is a point layer and v.overlay works only with lines and areas...
Silvia
Pablo.
On Fri, Jan 22, 2010 at 4:05 PM, Silvia Franceschi
<silvia.franceschi@ing.unitn.it> wrote:
Thank you Pablo,
and areas...
Try v.select:
http://grass.osgeo.org/grass64/manuals/html64_user/v.select.html
