The idea is to create a point vector where points are assigned a
rotation angle value corresponding to the line last (or first) segment
orientation. Then you just have to call d.vect whith "icon=" and
"rot_column=" options.
Good luck!
Vincent
Le vendredi 24 janvier 2014 à 14:12 +0900, sgw00412@nifty.com a écrit :
Hollow grass users
I'm from Japan, and biggner.
I do not find how to draw line with arrow mark to line top (tip).
for exsample...
normally line;
line with arrow mark to line top (tip);
or
I read online manual and tried to command 'd.vect layer_name icon=basic/arrow1
', however nothing happend....
Good luck!
Vincent
> Hollow grass users
> for exsample...
> normally line;
> or
arrow1
> Does anyone to know it?
> Best
> Yasuo SHIMADA (japan weather associaton)
> grass-user mailing list
> grass-user@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
I'm not sure if it matches your needs or not, but see also d.rast.arrow and the d.barb addon (d.barb can take either raster or vector maps as input); for a single arrow symbol the d.mark addon script might help.
