[GRASS-user] How to embed a grass script (for example v.db.addcol) into a Pythonscript on windows?
sorry for the a html-mail twice ...
Von: Helmut Kudrnovsky <hellik@web.de>
Gesendet: 10.04.2010 00:43:47
An: Isaac Ullah <isaac.ullah@asu.edu>
Betreff: How to embed a grass script (for example v.db.addcol) into a Pythonscript on windows?
Hi Isaac,
sorry for my delayed answered, very busy in my normal job outside any gis.
what I've done (using the nightly builds of WinGrass7, http://josef.fsv.cvut.cz/wingrass/grass70/):
I've copied from http://grass.osgeo.org/wiki/GRASS_and_Python
all lines of code for the Display example in a text-file and saved this
in C:\Program Files\GRASS-70-SVN\scripts under for example test_h.py,
and this lines of code are working (python bundled by WinGrass7).
please open a ticket - if necessary - in trac (http://trac.osgeo.org/grass/) to keep
all important steps available for the community.
best regards
Helmut
Von: Isaac Ullah
Gesendet: 06.04.2010 20:51:25
An: Michael Barton <Michael.Barton@asu.edu>
Betreff: Re: [GRASS-dev] Fwd: [GRASS-user] How to embed a grass script (for example v.db.addcol) into a Pythonscript on windows?
See the attached screen capture for the error I get when I try to run grass python scripts. This happens regardless of which version of python I use (ie. bundled python2.5, or using Glynn's .bat to start Grass with my version of python2.6), and occurs whether or not I add command line args to the script call. AFAICT when importing the "subprocess" methods, python seems to think it needs to also import some commands from "collections", which it fails to find. Any ideas about this?
Isaac
On Sat, Apr 3, 2010 at 1:20 PM, Michael Barton <[Michael.Barton@asu.edu]> wrote:
Thanks.
I'm sending this along to students. I didn't realize that there is a nightly build of GRASS 7 too.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 SHESC), 480-727-0709 (CSDC)
www: [www.public.asu.edu/~cmbarton], [http://csdc.asu.edu]
On Apr 3, 2010, at 12:07 PM, Helmut Kudrnovsky wrote:
Von: Michael Barton <[Michael.Barton@asu.edu]>
In a related question, maybe more for Colin, does GRASS 7 work in
Windows? If so, what is the setup to allow it to run the scripts in
Python?
GRASS 7 works in Windows using a similar batch file to that which I
posted for 6.x. However, the Init.bat file needs some work. Starting
with -wxpython doesn't work (you can start it manually via g.gui,
though). If you start in -text mode, you'll get a couple of errors
about the missing set_data program, but you'll end up in a session
using the existing .grassrc7 file (provided that one exists).
for testing there is a nightly build of WinGrass7:
[http://grass.osgeo.org/download/software.php\]
[http://josef.fsv.cvut.cz/wingrass/grass70/\]
best regards
Helmut
Isaac I Ullah, M.A.
Archaeology PhD Candidate,
ASU School of Evolution and Social Change
Research Assistant,
Mediterranean Landscape Dynamics Project
[isaac.ullah@asu.edu]
[ullah@archaeologist.com]
[http://www.public.asu.edu/~iullah\]
___________________________________________________________
GRATIS für alle WEB.DE-Nutzer: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://movieflat.web.de
