On Feb 28, 2008, at 6:32 PM, grass-user-request@lists.osgeo.org wrote:
Date: Thu, 28 Feb 2008 16:17:17 -0800
Subject: Re: [GRASS-user] How to find out an angle between to points
on the map (for r.plane, r.lake)
To: grass-user@lists.osgeo.org
Message-ID: <200802281617.17608.dylan.beaudette@gmail.com>
Content-Type: text/plain; charset="iso-8859-15"
On Thursday 28 February 2008, Philipp Steigenberger wrote:
Hi
I want to work with r.plane and r.lake to get simulate floodings in DTMs.
In the section of interest there is a river which runs from about SSW to
NNE. For r.plane I need the
azimuth. Is there a tool in GRASS which tells me the angle between two
points I mark on the map like I can measure in between two points with
d.measure?
Well of course I had to go and try this out.
attached is a patch (against todays SVN) to optionally print the bearing
between clicks.
Dylan
In the new wxPython GUI, the measure tool prints bearing as well as distance between click points.
On Thu, Feb 28, 2008 at 9:36 PM, Michael Barton <michael.barton@asu.edu> wrote:
> From: Dylan Beaudette <dylan.beaudette@gmail.com>
>> Hi
>> in DTMs.
>> SSW to
>> two
>> with
>> d.measure?
> bearing
> between clicks.
> Dylan
Michael
Thanks for the update. I don't regularly use either of the GUI and did
not know about this feature. Does the patch that I submitted interfere
with this functionality? I think that it would be useful to have this
functionality in the old style monitors as well.
If I remember, your patch is to d.measure? We don't use any of the old interactive xterm commands. In fact, you can't use them anywhere except in an xterm.
Michael
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
Hi
in DTMs.
SSW to
two
with
d.measure?
bearing
between clicks.
Dylan
Michael
d.measure is not used in wxGUI. Display windows are not registered as
GRASS displays (d.mon -L) [TODO, not sure how to implemented], I think
it would be good to use d.measure or something like g.measure in wxGUI
too instead of using Python-based function for distance calculation
(at least it would make sense for LL projections)? Please correct me
if I am wrong.
except in an xterm.
Michael
Hi Michael,
Right -- this patch was to d.measure, so it sounds like it will not interfere
with the workings of the GUI.
Dylan
USA
>>>> Hi
>>>> in DTMs.
>>>> SSW to
>>>> two
>>>> with
>>>> d.measure?
>>> bearing
>>> between clicks.
>>> Dylan
>> Michael
> Cheers,
> Dylan
if I am wrong.
2008/3/1, Michael Barton <michael.barton@asu.edu>:
> 2008/2/29, Dylan Beaudette <dylan.beaudette@gmail.com>:
> [snip]
>> did
>> interfere
>> this
> if I am wrong.
Michael,
What's wrong with the Python one?
duplication of the code, and in this particular case ignoring geodetic
distance for LL projections.
