[GRASS-user] How to find shortest distances from the
Dear Markus and all
Thank you advice...it gradually becomes difficult....
Which projection are you using? Please tell us the
output of
g.proj -w
GEOGCS["unnamed",
    DATUM["unknown",
        SPHEROID["unnamed",6378137,298.2572235630001]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
grass version :6.2.3
os: andLinux (ubuntu version)
I made Project Locatio by using EPSG code at start menu.
code no: 4030 <wgs84>
line and point data peojection as follows;
v.info shoreline
Projection: Lat/Lon (zone 0)
           N: 45.478 S: 41.462
           E: 145.778 W: 139.839
v.info investigation_points
           N: 45.526 S: 41.352
           E: 145.818 W: 139.334
Yasuo shimada
Dear Yasuo Shimada,
On Sat, May 9, 2009 at 10:07 AM, <SGW00412@nifty.com> wrote:
Dear Markus and all
output of
g.proj -w
GEOGCS["unnamed",
DATUM["unknown",
I *think* that you picked the wrong EPSG code. If you want
LatLong-WGS84, then use EPSG 4326.
See also:
http://spatialreference.org/ref/epsg/4326
best
