I have to find the maximum value for each cell in a series of rasters and
generate both a maximum value map and a categorical map with the raster
number which contains the maximum value.
R.series is, therefore, perfect to accomplish that using
method=maximum,max_raster.
My problem is that I also need to find the *second largest* value and the
corresponding raster number which contains the second largest value.
I am doing that by iterating over all classes through a shell script, but it
obviously takes much more time than using a simple r.series command.
Can anyone share any idea on how to accomplish that using r.series or
something similar?
something similar?
Thanks in advance for your thoughts.
Since you have the max_raster value, can't you just take that map out of the list you submit to r.series and find the new max_raster and value ?
Since you have the max_raster value, can’t you just take that map out of the list you submit to r.series and find the new max_raster and value ?
Unfortunately, I can’t. There is not on single map which is the maximum everywhere. The calculation is done in a cell-by-cell basis, so different maps have the maximum value locally.
Somehow, if after identifying the maximum value, I could make it zero or -9999, for instance, then I could re-run r.series to get the second largest value, but I don’t know how to do it.
of rasters and generate both a maximum value map and a
categorical map with the raster number which contains the
maximum value.
maximum value.
something similar?
There isn't an efficient way to do this using existing tools. If you
need the efficiency, I suggest adding a "second largest" aggregate to
lib/stats (based upon c_max.c and c_maxx.c), and updating r.series to
use it.
My problem is that I also need to find the second largest value and the
something similar?
Glynn:
There isn’t an efficient way to do this using existing tools. If you
need the efficiency, I suggest adding a “second largest” aggregate to
use it.
Thanks for pointing me the way. I think it is a little beyond my skills, but I might give it a try.
what about computing the first largest value, making your categorical map, and using it as a mask ?
if you mask all cell containing the first largest value, then the second largest value will become the first largest value of the masked raster serie …
something similar?
Glynn:
use it.
serie ...
Every cell has a largest value (provided that the cell is non-null in
at least one input map).
The problem can be solved by running "r.series method=max_raster",
then filtering each input map, setting a cell to null if the input
map has the largest value for that particular cell, then running
"r.series method=max" on the filtered maps.
But that's very inefficient compared to implementing a
"second-largest" aggregate directly.
