On 9/16/07 1:29 AM, "Raffaello Brondi" <raffaello.brondi@pisa.intecs.it>
wrote:
Wolf Bergenheim wrote:
On 12.09.2007 20:01, Raffaello Brondi wrote:
4. region = the intersection of raster1 and raster2 --> ?
As far as i see, using the g.region command, there is no way to specify
the last point except to manually set the nord,sud,ovest and east
values, but unfortunately i can not use this way.
Is there any other command in GRASS that i can use instead of g.region
to set the current region as the intersection of two rasters?
Hello,
I assume you have some kind of programing language which executes grass
commands. Can you parse the output? If so then you could do it like this:
g.region rast=raster1
g.region -p (parse the output, into rast1north, rast1east, rast1west,
rast1south, etc)
g.region rast=raster2
g.region -p (parse the output, into rast2north, rast2east, rast2west,
rast2south, etc)
g.region north=(min of rast1north, rast2northe) etc for other parameters.
Hope this helps,
--Wolf
Hello Wolf
Yes, the service i'm developing is written in Java.
Your solution is a good one but the problem is the overhead it introduces.
Since i can't (or maybe i'm not able to
) interact directly with
GRASS using Java, i would need to make 4 files reading/writing.
Here is probably the fastest way to do this, using Python syntax (I think
I've got it right, but it IS Monday morning), which is similar to Java
(which I don't know).
# use -ugp to output region parameters in an easy to parse format without
# changing the region
map1 = subprocess.Popen(cmd=['g.region', '-ugp', 'rast=rast1'])
map2 = subprocess.Popen(cmd=['g.region', '-ugp', 'rast=rast2'])
# parse g.region output for each raster
map1 = map1.split('\n')
map2 = map1.split('\n')
for coord in map1:
if 'n=' in coord:
north1 = coord.split('=')[1]
elif 's=' in coord:
south1 = coord.split('=')[1]
elif 'e=' in coord:
east1 = coord.split('=')[1]
elif 'w=' in coord:
west1 = coord.split('=')[1]
for coord in map2:
if 'n=' in coord:
north2 = coord.split('=')[1]
elif 's=' in coord:
south2 = coord.split('=')[1]
elif 'e=' in coord:
east2 = coord.split('=')[1]
elif 'w=' in coord:
west2 = coord.split('=')[1]
# create a new region that is the intersection of rast1 and rast2
subprocess.Popen(cmd=['g.region', 'n=%s' % min(north1, north2), \
's=%s' % max(south1, south2), 'e=%s' % min(east1, east2), \
'w=%s' % max(west1, west2) ]
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
