A friend works with LIDAR data. He needs to write a program with which
he extracts (from an vector ASCII x,y,z file) the row containing the
maximum z (height) and write a new vector ASCII containing the result.
(He writes in C++)
Since he deals with lots of ASCII files he needs to batch this job.
How about doing this in GRASS? With R maybe?
Thank you,
Nikos
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
On Jan 5, 2008 5:17 PM, Nikos Alexandris
(He writes in C++)
It would be good to extend v.univar to also analyze the geometry
statistics. I was seeking for the same functionality recently.
> (He writes in C++)
Your task sounds like it would be best done by a small script or C
program. Just read the data in a line-at-a-time and check if the
current line is larger than the previously stored line. At the end of
the file, print out the largest line (to a file if you have multiple
results to store). Probably 5 or 6 lines of Perl/Python at most and
you would be able to read arbitrarily huge files (millions of rows).
Most other solutions would introduce complexity or unnecessary
overhead. For lidar data, you may not have enough RAM to hold the
whole file in memory and the last thing you want to do is attach
topology to each point before you manipulate it.
grass-user mailing list
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Possibly code from r.in.xyz could be recycled for v.univar to operate
on the geometry. I also don't think that you could handle this in R, so
a C implementation is needed.
That works for an ASCII file, but I was thinking to generalize the use
cases. Ok, passing through R would require to much RAM, but anyway I
need to use a driver to handle the binary rasters (I'm saying this
because I have a similar task but with ArcINFO GRID files).
What would you do?
2008/1/6, Markus Neteler <neteler@osgeo.org>:
To print the line from an ASCII file with the maximum z-value, you could do
sort -n -k3 input_file.txt | tail -1
Bruce
What would you do?
> Markus
