[GRASS-user] How to Import and Export Maps Using Grass
I am programming a flight simulator and need to create landscape imagery. I
have downloaded the New York State orthoimagery available at
http://www.nysgis.state.ny.us/gateway/mg/2006/onondaga/
I now need to combine several image tiles into one, reduce their resulting
size, etc. How can I do this with Grass? I have never used Grass, but hope
somebody could point me to some applicable tutorials or outline the major
steps.
Basically, I'd like to be able to view the imagery as a set of combined
images and then be able to output areas at specific pixel resolutions.
View this message in context: http://n2.nabble.com/How-to-Import-and-Export-Maps-Using-Grass-tp4404433p4404433.html
This would be the r.patch command:
http://grass.osgeo.org/grass64/manuals/html64_user/r.patch.html
Procedure:
g.region rast=map1,map2,map3[,map4...] -p
r.patch input=map1,map2,map3[,map4...] output=hugemap
reduce their resulting size
That's r.resamp.stats - Resamples raster map layers to a coarser grid
using aggregation.
http://grass.osgeo.org/grass64/manuals/html64_user/r.resamp.stats.html
g.region res=xx
# with xx a number which is the destination pixel resolution
r.resamp.stats input=hugemap output=hugemap_lowres
Then export (e.g. GeoTIFF):
r.out.gdal input=hugemap_lowres output=hugemap_lowres.tif
steps.
Hope above gives an indication. Otherwise there is material here to read:
http://grass.osgeo.org/gdp/
landscape imagery. I have downloaded the New York State
(see also the now mostly defunct (mature?) terragear project at
http://terragear.org/ which supplies the SRTM landscapes for FlightGear)
see the g.region and r.patch modules:
g.region rast=map1,map2,map3,...
r.patch in=map1,map2,map3,... out=patched map
reduce their resulting size, etc.
see the 'g.region res=' and r.resamp.* modules.
of combined images and then be able to output areas at specific
pixel resolutions.
sure, sounds perfectly reasonable.
Hamish
