Simone Gabbriellini wrote:
Hello List,
Hello Simone,
this is my first attempt with Grass,
Have a nice ride with GRASS GIS :-). Invest some time, it'll "payback"
multiple times. As a starter, it is advised to warm-up with some stuff over
at:
<http://grasswiki.osgeo.org/wiki/GRASS_Help#First_Day_Documentation>\.
First thing you need to do in any case, is to set-up a location based on the
spatial reference system of the data you plan to work with.
Check some stuff here: <http://grass.osgeo.org/grass64/manuals/helptext.html>
and here: <http://grasswiki.osgeo.org/wiki/Importing_data>\.
I am trying to visualize administrative boundaries of India... I am trying
to load e00 files that I downloaded from
http://data.geocomm.com/catalog/IN/group109.html
So, GRASS GIS has its own vector (and raster) formats. You need to import the
data first in GRASS' data base.
Now, I really cannot understand how to import these data.
For "e00" files, there is a module called "v.in.e00". The help/manual pages
is: http://grass.osgeo.org/grass64/manuals/v.in.e00.html
You need to use this module in order to get the data of interest inside GRASS'
data base.
I don't understand the coordinates type of these data, thus I do not know
what to specify when Grass starts.
I had a quick look. The data are "nailed" in geographic coordinates. The
"ESPG" code for the "WGS84" reference system is "4326". You need to define a
new grass location based on the "EPSG:4326". There are also other ways to do
that, not only the epsg-code.
The error message I have is:
WARNING: Datum <Not_specified_based_on_Clarke_1866_ellipsoid> not
recognised by GRASS and no parameters found
ERROR: Projection of dataset does not appear to match current location.
I know this is not much information, but really I have no clue of what
I have to do in order to display these data, so any hint/advice on
best practice about how to proceed will be more than welcome.
After importing, set the active region to match the extent of the data (you
imported/you want to display, edit, et.c.):
"g.region vect=ImportedData" in the command line.
Best regards,
Simone
Give it a try, report back if things don't roll.
Best, Nikos
