[GRASS-user] How to import KML polygons in GRASS?
Maybe I am just loosin' my time struggling to import KML polygons in
GRASS but here is my attempt and my problems. I have read past threads
but I didn't really found the "SOLUTION"
I understand that it should be easy to play with xpath and xslt but
since KML's are XML's but, again, I have no idea about xpath and xslt
and I try do it the way I "know" more or less... ;-p
If there is already a solution... I would be more than greatful since I
am in the last phase of my current work.
Here is my attempt to import coordinates the "hard way":
1. Decompress KMZ and get the "KML"
# I was told, and I read, that KML are just XML's. So...
2. Replacing the KMLheader <kml xmlns="http://earth.google.com/kml/2.2&quot;&gt;
with
<?xml-stylesheet type="text/xsl" href="kml2html.xsl" ?>
<kml>
3. Saving the KML file in the same folder with an .xsl (in my case
kml2html.xsl given by a friend --- file attached)
4. Open with a browser and either (a) "copy-paste" the coordinates
for which I am interested or (b) "save as" txt file.
5. I choose (a) for my first attempt and save some coordinates in a txt
file and try to import them "sacrificing" the meta-data.
["example.xyz" with coordinates attached.]
The problem is that the coordinates are given in form of x,y,z but
continuously... that is one "x,y,z" field after another separated by
"space" and not in separate lines!
It looks like this:
x1,y1,z1 x2,y2,z2 x3,y3,z3 [...] xi,yi,zi
and NOT like this:
x1,y1,z1
x2,y2,z
x3,y3,z3
xi,yi,zi
6. I have studied v.out.ascii (since it is the reverse of v.in.ascii)
and I came up with this bash loop which WORKS in the command line. I can
import the desired coordinates in GRASS and I think it should be easy to
"clean" and convert in areas.
["example.grass-ready.xyz" attached]
The problem is that my "solution" DOES NOT work in a script due to an
error in "cut -d ' ' -f$i #### How can I use in -f a variable (stepwise
increasing number) instead of a constant number?
INPUT=example.xyz
OUTPUT= just a name
TYPE=B ### "B" for "boundaries" ...or "L" for lines better?
i=0
PRIMITIVES="`cat $INPUT | wc -w`"
echo "$TYPE $PRIMITIVES" > $OUTPUT.grass-ready; cat $OUTPUT.grass-ready
| echo "\nVERTI:">> $OUTPUT.grass-ready
until [ $i -gt $PRIMITIVES ]; do cat $INPUT | cut -d' ' -f$i | tr ',' '
' >> $OUTPUT.grass-ready; let i=i+1; done ### Note in tr ',' ' ' --
second character is a space
7. If this is going to work I was thinking to "grep" somehow the
metadata out of the "saved as txt file" and force it with a script in
the X.grass-ready ascii
Some more questions:
* ogr officially supports "KML" reading and writing. I can't read with
ogrinfo any KML file. I have read about "expat" support... but isn't
this activated by default in ogr coming with FWTools?
Sorry for the QGIS question:
* QGIS suppports GML reading?
(attachments)
kml2html.xsl (511 Bytes)
example.xyz (2.57 KB)
example.grass-ready.xyz (2.67 KB)
WOW!
Finally... I have got working using this
http://spanring.name/blog/wp-content/files/kml2gml.xsl
from here http://www.perrygeo.net/wordpress/?p=3
which most of you must be already aware I suppose!
Cool... it works since QGIS does read GML's.
I am still interested in my "SOLUTION" (especially in the "-f" parameter
in the "cur" command).
Does ogr2ogr convert from GML to GRASS vector files?
Oh... I am trying it out right away... :wink:
with
<kml>
It looks like this:
and NOT like this:
x1,y1,z1
x2,y2,z
x3,y3,z3
xi,yi,zi
INPUT=example.xyz
OUTPUT= just a name
i=0
grass-user mailing list
grass-user@lists.osgeo.org
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
No, but it does convert KML to whatever else, and you can import ogr
datasources (=KML for instance) directly into GRASS.
\\kristian
... et nemo ex vobis interrogat me: »Quo vadis?«
I did try that in the past without success. I will try again...
Do you have a practical example maybe?
Nikos
\\kristian
I haven't used KML for much, but here:
http://quovadis.dk/index.cgi/grass_is_greener%3A2008-02-17%3Ageo%2Cgrass
is a general example showing reading an ogr datasource into GRASS. If
you got the KML > GML working, you should be able to use the GML file as
the ogr dsn.
\\kristian
Nikos Alexandris pisze:
http://www.gdal.org/ogr/drv_kml.html
Maciek
Thanks for your feedback Kristian.
I got the KML > GML indirectly using a kml2gml.xsl.
I didn't get it directly.
Nikos
the ogr dsn.
\\kristian
$ ogrinfo -ro Korinthia_2007.kml
FAILURE:
Unable to open datasource `Korinthia_2007.kml' with the following
drivers.
"ML reading is only available if GDAL/OGR is built with the Expat XML Parser, otherwise only KML writing will be supported." [1]
[1]http://www.gdal.org/ogr/drv_kml.html
Yes,
I read that. But I read that this is enabled with FWTools!
Sorry if I am wrong... I am doanloading and trying again.
Many thanks for your time,
Nikos :wink:
> FAILURE:
> drivers.
$ ogr2ogr --help
should show you a list of supported drivers.
\\kristian
First of all:
I am sorry for the mail traffic.
I know it's bothering... but I am really stuck and confused.
I got KML and GML read/write support.
But is Expat an additional driver or just a library?
I can locate an "expat" library in my FWTools folder!
FYI:
$ ogrinfo --formats
Supported Formats:
  -> "GRASS" (readonly)
  -> "ESRI Shapefile" (read/write)
  -> "MapInfo File" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "DGN" (read/write)
  -> "VRT" (readonly)
  -> "AVCBin" (readonly)
  -> "REC" (readonly)
  -> "Memory" (read/write)
  -> "CSV" (read/write)
  -> "GML" (read/write)
  -> "KML" (read/write)
  -> "Interlis 1" (read/write)
  -> "Interlis 2" (read/write)
  -> "SQLite" (read/write)
  -> "ODBC" (read/write)
  -> "PGeo" (readonly)
  -> "OGDI" (readonly)
  -> "PostgreSQL" (read/write)
  -> "MySQL" (read/write)
$ ogr2ogr --help
\\kristian
Nikos Alexandris
OK,
I can open correctly the kml and the gml file with OpenEV which means I
got support for both.
But I wonder why can't I read/ wrtie successfully in the command line or
within GRASS (v.in.ogr)
Am I maybe using another GDAL/OGR version... since I compiled GRASS
manually! I don't remember defining GDAL/OGR when I compiled GRASS
sources...
Maybe I need to sort out some things... in my machine :stuck_out_tongue_winking_eye:
Once again sorry for the mail-bombing!
You might try using v.in.gpsbabel,
  http://www.gpsbabel.org/htmldoc-1.3.0/fmt_kml.html
  http://www.gpsbabel.org/htmldoc-1.3.0/fmt_google.html
It looks like this:
and NOT like this:
x1,y1,z1
x2,y2,z
x3,y3,z3
xi,yi,zi
perhaps:
cat infile | tr ' ' '\n' > outfile
edit outfile, add "L "
v.in.ascii
or search & replace in nedit or some nice editor.
see v.in.garmin, v.in.gpsbabel for awk magic to add "L number" to lines
automatically.
see v.in.garmin, v.in.gpsbabel for ideas on creating a DB table and
linking it to lines by cat number.
with ogrinfo any KML file. I have read about "expat" support...
but isn't this activated by default in ogr coming with FWTools?
fyi expat:
$ apt-cache show libexpat1
Description: XML parsing C library - runtime library
This package contains the runtime, shared library of expat, the C
library for parsing XML.
If you find a nice solution could you add some instructions on the
wiki?
Including all the links people have mentioned.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hamish,
thank you. You are always there... :wink:
I tried that in the past. I will re-check it.
> It looks like this:
> and NOT like this:
> x1,y1,z1
> x2,y2,z
> x3,y3,z3
> xi,yi,zi
perhaps:
v.in.ascii
automatically.
Checking that as well...
fyi expat:
hmmm... I see. -- yes I have it.
wiki?
If I make it "merging" all this advices I will definitely do that!
Hamish
Nikos
Nikos Alexandris
You can try what I do, which is to convert the kml to a shapefile with whatever transformation one wants. Then import the shapefile with v.in.ogr.
The ogr2ogr command can look something like this:
ogr2ogr -s_srs EPSG:4326 -t_srs EPSG:26911 my_outfile.shp my_infile.kml
Best,
John
On Feb 24, 2008, at 12:03 PM, Nikos Alexandris wrote:
OK,
sources...
(Replying partially to myself)
Well,
afterall it works!
I removed gdal-bin (installed from Ubuntu repo's) and build gdal from
source.
With a simple ./configure - make - sudo make install I get gdal/ogr
almost working
( got expat support but lost something else ;-( )
I needed to add in /etc/ld.so.conf the line
"/usr/local/grass-6.3.svn/lib"
Now all works fine:
ogrinfo Korinthia_2007.kml
and
ogr2ogr -s_srs "EPSG:4326" -t_srs "EPSG:2100" test.shp
Korinthia_2007.kml
But I am still interested in the idea of grabbing x,y,z and make a
grass-ready-to-import ascii.
Or is it not wothwile to pursue?
Just for the records:
a. kml2html
             1. Rename "Korinthia_estimate_2007.kml" to
                "Korinthia_estimate_2007.xml" and save on the same
                directory with "kml2html.xsl." [1]
             2. Edit the xml file and replace
                with
                 <kml>
             3. Save and open with a browser to read content
b. kml2gml
     1. (Same as above but this time save with kml2gml [2])
     2. (Same as above but this time replace with
         <?xml-stylesheet type="text/xsl" href="kml2gml.xsl" ?>
         <kml>
     3. Open xml with browser and save as gml file
     4. Open with... QGIS for example
c. Of course the easiest way is to get kml read/write support for OGR
and open directly kml files with OpenEV, QGIS or convert directly
with ogr2ogr in other formats.
[1] http://tilaphos.googlepages.com/kml2html.xsl
[2] http://spanring.name/blog/wp-content/files/kml2gml.xsl
