The errors are below:
user@osgeolive:~$ sudo sh grass-6.5.svn-x86_64-unknown-linux-gnu-20_10_2012-install.sh grass-6.5.svn-x86_64-unknown-linux-gnu-20_10_2012.tar.gz
Using gunzip decompressor…
The package grass-6.5.svn-x86_64-unknown-linux-gnu-20_10_2012.tar.gz seems to be o.k.
Proceeding…
Checking and creating installation directory…
Installing GRASS binaries into /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012
Uncompressing the package and extracting to target directory…
Creating start script:
/usr/local/bin/grass65 → /usr/local/bin/grass-6.5.svn-x86_64-unknown-linux-gnu-20_10_2012
Creating the locks directory for monitors…
Generating display font configuration file…
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/bin/g.mkfontcap: 1: /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/bin/g.mkfontcap: Syntax error: word unexpected (expecting “)”)
Installation finished. Start GRASS 6.5.svn-x86_64-unknown-linux-gnu-20_10_2012 with
Welcome to GRASS GIS. Enjoy this open source GRASS GIS!
user@osgeolive:~$ grass65
Cleaning up temporary files …
Starting GRASS …
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/clean_temp: 2: /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/clean_temp: Syntax error: word unexpected (expecting “)”)
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/clean_temp: 1: /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/clean_temp: ELF: not found
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/clean_temp: 1: /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/clean_temp: @@: not found
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/wxpython/gis_set.py”, line 36, in
from core import globalvar
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/wxpython/core/globalvar.py”, line 28, in
from core.debug import Debug
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/wxpython/core/debug.py”, line 67, in
Debug = DebugMsg()
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/wxpython/core/debug.py”, line 38, in init
self.SetLevel()
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/wxpython/core/debug.py”, line 43, in SetLevel
self.debuglevel = int(grass.gisenv().get(‘WX_DEBUG’, 0))
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/python/grass/script/core.py”, line 558, in gisenv
s = read_command(“g.gisenv”, flags=‘n’)
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/python/grass/script/core.py”, line 238, in read_command
ps = pipe_command(*args, **kwargs)
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/python/grass/script/core.py”, line 215, in pipe_command
return start_command(*args, **kwargs)
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/python/grass/script/core.py”, line 177, in start_command
return Popen(args, **popts)
File “/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/python/grass/script/core.py”, line 56, in init
startupinfo, creationflags)
File “/usr/lib/python2.7/subprocess.py”, line 679, in init
errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1249, in _execute_child
raise child_exception
OSError: [Errno 8] Exec format error
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/set_data: 1: /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/set_data: ELF: not found
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/set_data: 1: /usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-20_10_2012/etc/set_data: Syntax error: Unterminated quoted string
Thanks!
-----原始邮件-----
发件人: “Markus Neteler” neteler@osgeo.org
发送时间: 2012年10月25日 星期四
收件人: “王德辉” dehuiw@gig.ac.cn
抄送: grass-user@lists.osgeo.org
主题: Re: [GRASS-user] how to install GRASS binaries of weekly snapshot on ubuntu12.04?
On Wed, Oct 24, 2012 at 2:38 PM, 王德辉 dehuiw@gig.ac.cn wrote:
Hi,all
Although I set the lib links according to
http://grass.fbk.eu/grass65/binary/linux/snapshot/ , I still can not
install GRASS binaries (6.4.3,6.5,7.0) of weekly snapshot on ubuntu12.04 and
osgeolives (5.5 and 6.0). Doe anyone install the binary GRASS softwares
successfully?
Please tell us what the problem is. Note that these generic binaries
are generated on a 64bit Debian machine.
