[GRASS-user] How to link or combine adjacent vector lines
Stefan wrote:
Thanks for the detailed answer, but, my problem is much more trivial.
I attached a screenshot to make myself more clear.
/* The numbers refer to the categories of each line segment */
the tributary with cat 69 is fine, but the man channel consists of
multiple lines, and, in fact, a lot of tributaries look similar.
The task would be, to tell GRASS, to combine all lines of the main
channel, for this example.
ok. do they overlap or join end-to-end?
if they join, try Markus M's suggestion of v.build.polylines.
if they overlap, try 'v.clean tool=rmdupl'
Hamish
That did the trick, almost.
They join each other -so v.build polylines … worked, but, the table is exactly the same as it was before. The command output said, that the number of lines was reduced to almost 50%. Furthermore, if I check the cat number next to the lines (via d.vect) it looks fine for both methods, first and multi. But the table does not show any diffs and holds the same number of entries like the original one. I could not find anything about that in the manual.
Anyway, thanks for hints, that helped a lot.
Stefan
Hamish
They join each other -so v.build polylines ... worked, but, the table is
With options first and multi v.build.polylines just copies the attribute tables as is, i.e. it does not delete any lines for which there are no more category values in the vector file.
To create an attribute table that corresponds to the current vector amp with the following steps (supposing that the vector map is called river_poly):
db.copy from_table=river_poly to_table=river_bak # create backup of existing table
v.db.connect -d river_poly # erase line between vector map and table river_poly
db.droptable river_poly # erase table river_poly
v.db.addtable river_poly # create new table for vector map river_poly
If you do all this using an SQL backend (e.g. SQLite or PostgreSQL), you can then use v.db.join to join any attributes from the original table river_bak to the new table river_poly.
Moritz
vector file.
river_poly
table river_poly.
would 'v.extract list=1-9999999' also work?
Hamish
vector file.
river_poly
table river_poly.
Yep, and it's a bit shorter than my solution while keeping all the original attributes without having to go through v.db.join ... :wink:
Moritz
I tried the short one of course , worked perfectly :wink:
Thanks a lot for your efforts.
stefan
> vector file.
> river_poly
> table river_poly.
Hamish
