[GRASS-user] How to make a LOCATION corresponding to JGD2000 CS III
I want to create a LOCATION corresponding to JGD2000 CS III which
is defined in epsg.
I tried to create it as following,
coordinate system : Other Projection
projection name : tmerc
geodetic datum : custom
ellipsoid name : GRS80
towgs84=0,0,0,0,0,0,0
Scale Factor : 0.9999
Central Parallel : 36N
But I could not input the next item "Central Meridian".
In epsg definition, the central meridian of JGD2000 CS III is
"+lon_0=132.1666666666667", so an error message was appeared.
The message is "132.1666666666667E is invalid for longitude".
Please let me know how to create that LOCATION.
Masayuki Naruse <pockel@nifty.ne.jp>
which is defined in epsg.
in the GUI startup you could try "create new location from EPSG code",
or the same from within another grass location with 'g.proj loc= epsg='
try 132.1666666666667 (decimal form uses +/- not E/W), or 132:10E.
Hamish
