I wrote a script to do something like this at one point, though I can’t find it now. It was intended for terrain, but could be used per band on imagery. It used r.buffer to create a distance gradient and then r.recode to convert this gradient to a percentage. I then used r.mapcalc to merge the 2 rasters based on the percentage.
The script automated the buffer distances and the creation of the recode.txt file, but went something like this:
make a null raster
r.mapcalc “temp_null = if(isnull(source),1,null)”
create a distance gradient from the null raster. The output will have int values 1-7 where 1 equals the input null raster
r.buffer in=temp_null out=temp_buf distances=10,20,30,40,50,60 units=meters
fill nulls in the distance gradient with 0 for recoding
r.mapcalc “temp_buf_fill=if(isnull(temp_buf),0,temp_buf)”
recode to a percentage
r.recode in=temp_buf_fill out=temp_recode rules=recode.txt
where recode.txt would have the range from temp_buf_fill expressed as percentages:
1:1:100:100
2:2:86:86
3:3:71:71
4:4:57:57
5:5:43:43
6:6:29:29
7:7:14:14
0:0:0:0
merge the output
r.mapcalc “merged=if(isnull(source),patch,(patch*(temp_recode/100.0))+(source*(1.0-(temp_recode/100.0))))”
Sorry if that doesn’t work, but hopefully you get the idea.
On Thu, Feb 24, 2011 at 10:53 AM, kaipi <mapcollect@gmx.net> wrote:
I need to patch rasters containing NULL areas with alternative rasters. I can
do this with r.patch but due to different quality/resolution of the rasters
this produces prominent seamlines. Is there a way to feather/blend between
merged rasters using Grass GIS?
Kaipi
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-merge-rasters-using-feathering-blending-tp6061489p6061489.html
grass-user mailing list
grass-user@lists.osgeo.org
