Hi All,
Is it possible make a map with a grid or a grid layer in the Cartographic Composer?
Thanks in advance,
Marcello Benigno B. de Barros Filho
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
2012/2/1 Marcello Benigno <benigno.marcello@gmail.com>:
Hi All,
Composer?
So far it's not possible, but you can at least export script for
ps.map module from composer, edit it and then run with ps.map module.
See ps.map manual page [1]. If you are interested, video tutorials
for composer are available here [2].
Anna
[1] http://grass.fbk.eu/grass70/manuals/html70_user/ps.map.html#grid
[2] http://grass.osgeo.org/wiki/WxGUI_Cartographic_Composer#Video_tutorial
Thanks in advance,
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Anna, Works fine
Just a tip, what is the best program to open and manipulate GRASS maps in .ps format? GIMP or Inkscape?
Regards
2012/2/1 Anna Kratochvílová <kratochanna@gmail.com>
Hi All,
Composer?
So far it’s not possible, but you can at least export script for
Anna
Thanks in advance,
