[GRASS-user] How to quote temporal algebra expressions when using the inverse selection operator ! ?
In one of the t.rast.algebra related tests, the use of the ! operator is demonstrated [0]:
t.rast.algebra", expression="R = A {!:,during} C", basename="r"
[0] https://github.com/OSGeo/grass/blob/99464f8f520a8778564bafa9b2b47bcd8f893bf8/temporal/t.rast.algebra/testsuite/test_raster_algebra.py#L642)
I can't seem however to use it properly (in the command line, Linux, bash ver. 5.0.7).
This
t.select -d expression="C = a1 : a2"
works, while this
t.select -d expression="C = a1 !: a2"
fails with
bash:  : unrecognized history modifier
How should such an expression be quoted?
Thanks, Nikos
bash ver. 5.0.7).
This
works, while this
fails with
Unsure if the following is correct, it seems to work here:
for RELATION in equal follows precedes ;do
     t.select -s -d expression='A = A1 {!:, '"${RELATION}"'} A2'
done
Nikos
