[GRASS-user] How to remove nonexistent vector map
I am trying to run v.in.ogr against a PostGIS database. The command’s output is:
ERROR: Vector map already exists
Yet when I run g.remove pointdata, I get:
Removing raster
Raster map not found
nothing removed
But then you may say, “Hey, moron, that’s a vector layer! Use the right command.” OK, I ran g.remove vect=pointdata and I get:
Removing vector
DBMI-DBF driver error:
Unable to open database <cat C:\Users\Aren Cambre\Desktop\DEEM documents\GRASS\DallasCountyCrashes\Crases2\dbf> by driver
Unable open database <cat C:\Users\Aren Cambre\Desktop\DEEM documents\GRASS\DallasCountyCrashes\Crases2\dbf> by driver
Unable to find table linked to vector map
couldn’t be removed
nothing removed
Huh?
Aren
I’ve reported this as a bug: http://trac.osgeo.org/grass/ticket/1438
Removing raster
nothing removed
Removing vector
couldn’t be removed
nothing removed
Huh?
Aren
On Sun, 2011-09-04 at 22:10 -0500, Aren Cambre wrote:
I've reported this as a bug: http://trac.osgeo.org/grass/ticket/1438
should be a duplicate of
http://trac.osgeo.org/grass/ticket/1158
try GRASS svn, it should be fixed.
cheers
-- Giovanni --
Thanks. Marked 1438 as duplicate of 1158.
On Mon, Sep 5, 2011 at 2:19 AM, Giovanni Manghi <giovanni.manghi@gmail.com> wrote:
cheers
– Giovanni –
