[GRASS-user] how to resolve initdb
Hello !!
I am using cygwin 1.5.24 with postgres 8.0.7.
when i n initializing the data directory i m having following problem
$ /usr/sbin/initdb -D /usr/local/pgsql/data
The files belonging to this database system will be owned by user “pawan”.
This user must also own the server process.
The database cluster will be initialized with locale C.
modifica dei permessi sulla directory esistente /usr/local/pgsql/data … ok
creazione directory /usr/local/pgsql/data/global … ok
creazione directory /usr/local/pgsql/data/pg_xlog … ok
creazione directory /usr/local/pgsql/data/pg_xlog/archive_status … ok
creazione directory /usr/local/pgsql/data/pg_clog … ok
creazione directory /usr/local/pgsql/data/pg_subtrans … ok
creazione directory /usr/local/pgsql/data/base … ok
creazione directory /usr/local/pgsql/data/base/1 … ok
creazione directory /usr/local/pgsql/data/pg_tblspc … ok
selecting default max_connections … sh: line 1: 3576 Bad system call
“/usr/sbin/postgres.exe” -boot -x0 -F -c shared_buffers=500 -c max_connections=1
00 template1 < “/dev/null” > “/dev/null” 2>&1
sh: line 1: 3796 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=250 -c max_connections=50 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 2580 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=200 -c max_connections=40 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 3092 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=150 -c max_connections=30 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 1028 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=100 -c max_connections=20 template1 < “/dev/null” > “/dev/null
" 2>&1
sh: line 1: 1616 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=50 -c max_connections=10 template1 < “/dev/null” > “/dev/null”
2>&1
10
selecting default shared_buffers … sh: line 1: 1416 Bad system call "
/usr/sbin/postgres.exe” -boot -x0 -F -c shared_buffers=1000 -c max_connections=1
sh: line 1: 2492 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=900 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 612 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=800 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 1756 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=700 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 3656 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=600 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 2156 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=500 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 2084 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=400 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 1572 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=300 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 2352 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=200 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 3664 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
-c shared_buffers=100 -c max_connections=10 template1 < “/dev/null” > "/dev/null
" 2>&1
sh: line 1: 424 Bad system call “/usr/sbin/postgres.exe” -boot -x0 -F
2>&1
50
child process is terminated by signal 12
initdb: removing data directory “/usr/local/pgsql/data”
I have down the following before initdb command
  1. set CYGWIN=server
  2. /usr/sbin/cygserver.exe &
and cygrunsrv is not required anymore for 8.0.x versions.
Pawan
grassuser-request@grass.itc.it wrote:
Send grassuser mailing list submissions to
grassuser@grass.itc.it
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grassuser-owner@grass.itc.it
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grassuser digest…”
Today’s Topics:
  1. Benchmarking Grass 4.3, 5.4, 6.0, 6.2 raster commands
    (Roy Sanderson)
  2. Re: Problem with slope modeling . (Dylan Beaudette)
  3. Re: Problem with slope modeling . (Maciej Sieczka)
  4. Re: Benchmarking Grass 4.3, 5.4, 6.0, 6.2 raster commands
    (Glynn Clements)
  5. Re: [GRASS-dev] Re: [GRASS-user] Benchmarking Grass 4.3, 5.4,
    6.0, 6.2 raster commands (Helena Mitasova)
  6. Re: Problem with slope modeling . (Dylan Beaudette)
Message: 1
Date: Mon, 30 Apr 2007 15:28:12 +0000
Pawan Joshi
Ahhh…imagining that irresistible “new car” smell?
Check out new cars at Yahoo! Autos.
