Greetings
I have a raster layer and a vector point layer and I need to associate pixel values with points:
1- pixel values that are over points;
2- 3x3 pixel neighbor pixel values over a point.
Is this possible do to in a more automatic way than query each by each point?
Thanks
Regards
helena
Greetings
When you say “associate” If you mean to add the raster values to a column in the point vector attribute table, then v.what.rast is what you’re looking for.
Create a new raster with r.neighbors then run v.what.rast again to upload these 3x3 neighborhood values to another column in the point vector.
Here are the steps:
v.db.addcol vector_map col=“rast_val double, rast_val_3x3 double”
v.what.rast vector_map rast=raster_map col=rast_val
r.neighbors raster_map out=raster_map_3x3 # assumes averaging a 3x3 window
v.what.rast vector_map rast=raster_map_3x3 col=rast_val_3x3
Micha Silver
GIS Consultant, Arava Development Co.
[http://www.surfaces.co.il](http://www.surfaces.co.il)
Hi
I was thinking in something much simpler like just printing Pixel values next to Point ID.
I will give a try on your suggestions.
Thanks
2012/3/28 Micha Silver <micha@arava.co.il>
On 03/28/2012 08:11 PM, Helena Herrera wrote:
Greetings
Here are the steps:
Thanks
Regards
helena
This mail was received via Mail-SeCure System.
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Once you’ve added columns for the pixell values to the point vector, then you can, of course, display those attributes on your map.
Micha Silver
052-366-5918
-----Original message-----
To: Micha Silver micha@arava.co.il
Cc: grass-user@lists.osgeo.org
Sent: Thu, 29 Mar 2012, 14:36:12 GMT+02:00
Subject: Re: [GRASS-user] How to retrieve raster pixel value over a vector point layer
Hi
Thanks
Greetings
Here are the steps:
Thanks
Regards
helena
Micha Silver
