[GRASS-user] How to run a bash script - GRASS6.4 Windows
Hello,
I'm new using grass and bash scripting and my question is quiet simple.
I would like to know how I can run a bash script with the grass Command line (the black box!).
the box display
GRASS 6.4.2 <region>>
But then, I don't how to explain to the shell where the script I want he run. Could someone give me some guidance ?
This the path of my script : G:\3.Informatique-programmes\scripts_utilitaires\bash\grass
And the name : import_ETo_month.sh
Thank you
Lucien
On Fri, Mar 22, 2013 at 6:14 PM, BLANDENIER Lucien
<lucien.blandenier@unine.ch> wrote:
Hello,
the box display
The easiest way should be, within the GRASS terminal window:
- change to the directory in which the script is stored:
  cd G:\3.Informatique-programmes\scripts_utilitaires\bash\grass
- sh import_ETo_month.sh
Or, call the script with the full path.
Please note that shell script support is rather limited under Windows;
that's an important reason why all scripts were rewritten in Python
for GRASS 7.
