[GRASS-user] How to sample an STVDS based on an STRDS
I'm fairly new to the temporal features in GRASS. I think I'm looking for the inverse of t.rast.aggregate.ds - that is, I have an STRDS with arbitrary intervals (roughly, 24 day windows moving about every 6 days). I have an STVDS with daily data. I'd like to aggregate the daily STVDS to match the STRDS.
I can do this using t.sample, parse that, and aggregate. But this seems to be a fair amount of manual work, and it looks like GRASS abstracts much of this if I were going the other way - subsetting a STRDS based on an STVDS.
Is there a simple way to do this in GRASS - i.e. Is there a command I'm missing or mis-understanding? Or does subsetting vectors take more work because there is no analog to t.rast.aggregate.ds?
  -k.
Dear Ken,
there is no functionality for vector aggregation available in GRASS
GIS Temporal Framework. Dependent on your STVDS, maybe you can convert
it into a STRDS by using v.to.rast for each vector layer and then
organize the resulting raster layers in a new STRDS.
Best regards
Sören
2017-12-05 14:00 GMT+01:00 Ken Mankoff <mankoff@gmail.com>:
  -k.
grass-user mailing list
grass-user@lists.osgeo.org
Hi Sören,
OK - good to know I'm not missing anything.
Dependent on your STVDS, maybe you can convert it into a STRDS by
using v.to.rast for each vector layer and then organize the resulting
It would not be efficient to convert my 19-point STVDS's to rasters which have 100s of 1000s of cells.
It shouldn't be too hard to use the output of t.sample to generate aggregates myself. I'll take this route.
  -k.
