[GRASS-user] How to save raster histogram in png format from command line ?
Good day,
Is there any mogul of GRASS which will save histogram of a raster GeoTiff image in a png or jpeg file ?
As I understand, d.histogram is only displaying it, and you cannot use it in text mode.
Thank you in advance.
in text mode.
Most d.* commands can be made to generate an image by setting the
environment variable GRASS_RENDER_IMMEDIATE=TRUE. See the pngdriver
manual page for related environment variables.
Thank you very much for your suggested solution.
I did it a bit other way, but your solution helped me to find this on.
So, I did it this way
d.histogram map=somemap
and got the histogram in test.png file.
On Mon, Nov 26, 2012 at 5:12 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
