[GRASS-user] How to set layer opacity in maps created from command line? (Nikos Alexandris)
I think that r.blend may accomplish what I need, in terms of compositing rasters to achieve the effect of partial transparency in a layer. It is not clear to me how this will work when one or more of the layers that I want to composite has rgb channels and so is represented by three separate raster maps (one for each channel) in the mapset. Do I need to create an image group (i.group) of the three channels and use the group's name as 'first' or 'second' parameter for r.blend?
The documentation for r.blend seems to indicate that it can only blend two rasters at a time.
Message: 4
Date: Thu, 3 Oct 2013 11:44:38 -0600
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] How to set layer opacity in maps created from
  command line?
Message-ID: <B66987DB-8098-4B6E-9282-6EB3B6CFCE7D@gmail.com>
Content-Type: text/plain; charset=us-ascii
I am attempting to create maps from the command line, which are composites of several raster and vector layers. In order to visualize the data effectively, I need to vary the opacity of the layers. I have found that this is simple to achieve in the wxGUI, but the GUI does not display the underlying module call as it does with many other commands. A little Googling helped me to discover a module called g.pnmcomp, which was apparently used by the old Tcl/Tk GUI for managing layer opacity, but that module appears not to be intended for end users and I suspect that there is an easier and more direct way to achieve my desired results.
The process by which I'm creating my maps is essentially this sequence of commands (is there a better approach?):
g.region rast=region_raster.tif
d.mon start=PNG
d.rast map=some_raster.tif
d.rast map=another_raster.tif
d.vect map=some_vector.shp
d.mon stop=PNG
It seems to me that either d.mon or the PNG driver is doing the compositing and so would handle the opacity of the layers, but I can't find any documentation of how to specify values for opacity. This is surprising to me because it seems that what I'm trying to do is such a basic and commonly used operation in creating maps. What am I missing?
Message: 5
Date: Thu, 03 Oct 2013 22:03:27 +0300
Cc: Gregory Penn <gregory.penn@gmail.com>
Subject: Re: [GRASS-user] How to set layer opacity in maps created
  from command line?
Message-ID: <2374263.A5DhYUQC8g@resilience>
Content-Type: text/plain; charset="us-ascii"
Working on GRASS 6.x or 7?
results.
Check r.blend: <http://grass.osgeo.org/grass64/manuals/r.blend.html&gt;,
<http://grass.osgeo.org/grass70/manuals/r.blend.html&gt;\. The latter features a
"-c" flag, which does... "Combine resulting R,G,B layers into single output
map".
d.mon start=PNG
d.mon stop=PNG
Ah, this is GRASS6.x then. I think you can still blend maps and then maybe use
d.out.png to export? See
<http://grass.osgeo.org/grass64/manuals/d.out.png.html&gt;\.
Hope this is what you are looking for.
Nikos
grass-user mailing list
End of grass-user Digest, Vol 90, Issue 4
You can utilise r.composite, in first place, to compose Real- or Pseudo-RGBs.
<http://grass.osgeo.org/grass64/manuals/r.composite.html&gt;\. Try to find an
optimum for your RGBs (friends: r.colors, i.landsat.rgb).
See above. Note, anyhow, that you can export directly a group that consists
of three maps, say Red, Green and Blue bands of a satellite acquisition as an
example, by using the group's name directly with r.out.gdal. Maybe a useful
tip (?).
rasters at a time.
True. So, r.composite first. "r.blend" itself will produce R, G and B which
you need to display with d.rgb, then, I think, use d.out.png. Or, once again,
after "blending", r.composite the final R, G and B maps, then export
(r.out.gdal or d.out.*).
I think it'll work this way. Don't remember currently another way.
Best, Nikos
>> composites
Nikos:
>> desired results.
> features a "-c" flag, which does... "Combine resulting R,G,B layers into
> single output map".
>> d.mon start=PNG
>> d.mon stop=PNG
> use d.out.png to export? See
> Nikos
Pseudo-RGBs. <http://grass.osgeo.org/grass64/manuals/r.composite.html&gt;\. Try
to find an optimum for your RGBs (friends: r.colors, i.landsat.rgb).
Check also this set of instructions:
<http://casoilresource.lawr.ucdavis.edu/drupal/node/159&gt;\.
Nikos
