[GRASS-user] How to split a line using points?
I have points over a line and i need to split the line where the points are
located. The points aren’t at the same distance to each other. Any idea how
to do that?
If your points lie exactly on the line, you may do so (in Linux with bash) :
v.out.ascii format=point in=pts --q | cut -d’|’ -f1,2 | tr ‘|’ ‘,’ | while read COOR; do v.edit map=line tool=break coords=$COOR; done
