Dear all,
I would like to know if there is a way to store results of a calculation done with r.sum on many raster with a bash script.
I need to reuse these results in later calculations.
Thanks
Lucien
Dear all,
Thanks
Lucien
I might missed it but I don’t know about r.sum module. (I know only r.sun).
Saving standard output of module (if it prints something to standard output) is the same as for any other command line tool in bash. If the output is a map (in GRASS) just use it as input to some other module (using the map name).
Examples bellow show saving outputs of echo command to variables (echo command just print its parameters to standard output, i.e. to command line). Working with numbers (additions, multiplications) can be more difficult (requires different syntax) but there should be some online guides.
Vaclav
$ A=“some text”
$ echo $A
some text
$ B=echo "this is printed to stdout"
$ echo $B
$ C=$(echo “this is printed to stdout”)
$ echo $C
(lines beginning with $ are lines with command which are meant to by typed into the command line, the other lines are output)
On Sat, Jan 11, 2014 at 9:32 AM, BLANDENIER Lucien <lucien.blandenier@unine.ch> wrote:
Dear all,
Thanks
Lucien
grass-user mailing list
grass-user@lists.osgeo.org
Hello Vaclav,
I tried with the following script:
$C=$(r.sum rast=map@mapset)
$echo $C
SUM = 16116.500006
But I think the variable C stores all the command (r.sum rast=map@mapset) and not only the result. Do you know how it would be possible to store the result "SUM = 16116.500006"
Regards
Lucien
De : Vaclav Petras [wenzeslaus@gmail.com]
Envoyé : dimanche 12 janvier 2014 03:11
À : BLANDENIER Lucien
Cc : grass-user@lists.osgeo.org
Objet : Re: [GRASS-user] how to store results from r.sum with script
I might missed it but I don't know about r.sum module. (I know only r.sun).
Vaclav
$ A="some text"
$ echo $A
some text
$ B=`echo "this is printed to stdout"`
$ echo $B
$ C=$(echo "this is printed to stdout")
$ echo $C
On Sat, Jan 11, 2014 at 9:32 AM, BLANDENIER Lucien <lucien.blandenier@unine.ch<mailto:lucien.blandenier@unine.ch>> wrote:
Dear all,
Thanks
Lucien
grass-user@lists.osgeo.org<mailto:grass-user@lists.osgeo.org>
Try remove spaces from r.sum command output (e.g. using sed
) and since the results is
SUM=16116.500006
which is valid bash variable definition, you can use eval
command which will define the variable, so you can use it afterwards.
$ eval $(echo “SUM = 16116.500006” | sed -e “s/ //g”)
$ echo $SUM
16116.500006
I assume from what you have written that r.sum rast=map@mapset
prints
SUM = 16116.500006
to standard output. Knowing what is the output of that module is crucial. What module is this, do you have documentation? GRASS modules (in GRASS distribution) use the convention that if you use -g
flag they print the variables in “shell script style”, so you can use the output in eval function or parse it easily. They output would be
SUM = 16116.500006
On Mon, Jan 13, 2014 at 10:20 AM, BLANDENIER Lucien <lucien.blandenier@unine.ch> wrote:
Hello Vaclav,
$echo $C
SUM = 16116.500006But I think the variable C stores all the command (r.sum rast=map@mapset) and not only the result. Do you know how it would be possible to store the result “SUM = 16116.500006”
Regards
Lucien
Objet : Re: [GRASS-user] how to store results from r.sum with scriptHi,
Vaclav
$ A=“some text”
$ echo $A
some text$ B=
$ echo $B
this is printed to stdout$ C=$(echo “this is printed to stdout”)
$ echo $C
this is printed to stdout(lines beginning with $ are lines with command which are meant to by typed into the command line, the other lines are output)
On Sat, Jan 11, 2014 at 9:32 AM, BLANDENIER Lucien <lucien.blandenier@unine.chmailto:[lucien.blandenier@unine.ch](mailto:lucien.blandenier@unine.ch)> wrote:
Dear all,I would like to know if there is a way to store results of a calculation done with r.sum on many raster with a bash script.
Thanks
Lucien
grass-user@lists.osgeo.orgmailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
The -g flag is not valide for this module...
Do you know if there is others possibilities?
Thanks a lot
Lucien
Envoyé : lundi 13 janvier 2014 16:34
Try remove spaces from r.sum command output (e.g. using `sed`) and since the results is
SUM=16116.500006
which is valid bash variable definition, you can use `eval` command which will define the variable, so you can use it afterwards.
$ eval $(echo "SUM = 16116.500006" | sed -e "s/ //g")
$ echo $SUM
16116.500006
I assume from what you have written that `r.sum rast=map@mapset` prints
SUM = 16116.500006
to standard output. Knowing what is the output of that module is crucial. What module is this, do you have documentation? GRASS modules (in GRASS distribution) use the convention that if you use `-g` flag they print the variables in "shell script style", so you can use the output in eval function or parse it easily. They output would be
SUM = 16116.500006
On Mon, Jan 13, 2014 at 10:20 AM, BLANDENIER Lucien <lucien.blandenier@unine.ch<mailto:lucien.blandenier@unine.ch>> wrote:
Hello Vaclav,
$echo $C
SUM = 16116.500006
Regards
Lucien
De : Vaclav Petras [wenzeslaus@gmail.com<mailto:wenzeslaus@gmail.com>]
Cc : grass-user@lists.osgeo.org<mailto:grass-user@lists.osgeo.org>
Vaclav
$ A="some text"
$ echo $A
some text
$ echo $B
$ echo $C
On Sat, Jan 11, 2014 at 9:32 AM, BLANDENIER Lucien <lucien.blandenier@unine.ch<mailto:lucien.blandenier@unine.ch><mailto:lucien.blandenier@unine.ch>> wrote:
Dear all,
Thanks
Lucien
grass-user@lists.osgeo.org<mailto:grass-user@lists.osgeo.org><mailto:grass-user@lists.osgeo.org>
On Mon, Jan 13, 2014 at 10:42 AM, BLANDENIER Lucien <
OK, now I understand, r.sum was merged to
r.statistics<http://grass.osgeo.org/grass70/manuals/r.statistics.html>
, r.statistics2 <http://grass.osgeo.org/grass70/manuals/r.statistics2.html>
, r.statistics3 <http://grass.osgeo.org/grass70/manuals/r.statistics3.html> in
GRASS 7, it is available only in GRASS 6.
http://grass.osgeo.org/grass64/manuals/r.sum.html
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
Yes, use what I wrote before (explained in that email):
$ echo $SUM
16116.500006
For r.sum in GRASS 6 in NC sample location:
eval $(r.sum elevation | sed -e "s/ //g")
echo $SUM
27569640.087723
SUM_elevation=$SUM
echo $SUM_elevation
27569640.087723
or shorter
SUM_elevation=$(r.sum elevation | sed -e "s/SUM = //g")
echo $SUM_elevation
27569640.087723
Thanks a lot
Lucien
Objet : Re: [GRASS-user] how to store results from r.sum with scriptTry remove spaces from r.sum command output (e.g. using `sed`) and since
the results isSUM=16116.500006
will define the variable, so you can use it afterwards.$ eval $(echo "SUM = 16116.500006" | sed -e "s/ //g")
$ echo $SUM
16116.500006I assume from what you have written that `r.sum rast=map@mapset` prints
SUM = 16116.500006
function or parse it easily. They output would beSUM = 16116.500006
Hello Vaclav,I tried with the following script:
$echo $C
result "SUM = 16116.500006"Regards
Lucien
the map name).Examples bellow show saving outputs of echo command to variables (echo
guides.Vaclav
$ A="some text"
$ echo $A
some text$ B=`echo "this is printed to stdout"`
$ echo $B
this is printed to stdout$ C=$(echo "this is printed to stdout")
$ echo $C
into the command line, the other lines are output)On Sat, Jan 11, 2014 at 9:32 AM, BLANDENIER Lucien <
done with r.sum on many raster with a bash script.I need to reuse these results in later calculations.
Thanks
Lucien
grass-user@lists.osgeo.org<mailto:grass-user@lists.osgeo.org>>
