I haven't worked much with the vector features of grass. Is there a way to query if a given point is inside if a polygon (closed area)?
Many thanks
Wolfgang
Many thanks
Wolfgang
Don't know if there's a faster way, but i'll do this:
1 - Buffer (small radius) around points
2 - Intersection with polygons
3- Calculate the area of each intersection
4 - Extract the ones that are >0
Let me know
Bye
Luca
Il giorno 12/lug/07, alle ore 16:10, WolfgangZ ha scritto:
Many thanks
Wolfgang
v.select will allow you to select points which overlap areas or vice versa.
v.select ainput=points binput=areas output=points_in_areas
points_in_areas will contain points which are inside the areas.
--Wolf
On 12.07.2007 17:10, WolfgangZ wrote:
to query if a given point is inside if a polygon (closed area)?Many thanks
Wolfgang_______________________________________________
grassuser mailing list
grassuser@grass.itc.it
<:3 )---- Wolf Bergenheim ----( 8:>
--Wolf
Wolfgang
Hi Wolf,
thank for your help. There are sometimes too many commands in grass to find the right one!
Wolfgang
Now in the FAQ:
http://grass.gdf-hannover.de/wiki/Category:FAQ
-> Point in polygon
View this message in context: http://www.nabble.com/how-to-test-if-a-point-is-inside-a-polygon-tf4068417.html#a11565329
