I am sure this is ridiculously simple but I cannot find it …
I am running GRASS 7.4.4 on MacOSX. I clicked on “Show Current Region Extent in Map Display”. This created a red box on the display - as advertised.
I now want to turn it off and cannot find any way of doing it!
Thanks in advance
The option I found is under “Settings->Preferences->Map Display”. Uncheck the “Show Computational Region”. Then you have to restart the GUI to actually make it happen.
Thanks in advance
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Thanks for the advice. Unfortunately - it was already unchecked. I tried checiing it. Then unchecking it. Then restarting the GUI to no effect. I might just have to recreate the workspace from scratch.
And then - never go near that menu item again !
Thanks in advance
Micha Silver
Ben Gurion Univ.
you can also uncheck the checkbox in the lower left corner of the map display, see attached screenshot. This has immediate effect.
HTH,
Markus M
Thanks in advance
Micha Silver
Ben Gurion Univ.
(attachments)
I looked at a copy of 7.6.0 on Macos and 7.4.4 on Windows and neither copy had that tick box? Which version has it ?
On Sat, 9 Mar 2019 at 13:48, Markus Metz <markus.metz.giswork@gmail.com> wrote:
HTH,
Markus M
Thanks in advance
Micha Silver
Ben Gurion Univ.
In the center of the bottom status bar there should be a drop down to select the “mode” of the status bar. You can select “Show Comp. Extent”. Then that checkbox appears on the left.
HTH,
Markus M
Thanks in advance
Micha Silver
Ben Gurion Univ.
Ben Gurion Univ
Sde Boker
+972-523-665918
