[GRASS-user] How to unsubscribe from old mailing list?
Dear subscribers,
sorry, I forgot to explain how you unsubscribe from the
old GRASSLIST@baylor.edu list:
To unsubscribe, send email to:
  listproc@baylor.edu
from the address you used to subscribe to the list.
In the *body* of the message, write the command:
  unsubscribe GRASSLIST
Note: Please do not send "unsubscribe" messages to the
user mailing list - this won't work. You have to use the
listproc@baylor.edu email address as indicated above.
On Thu, May 11, 2006 at 09:27:21AM -0500, Steven Gordon wrote:
Hello,
I am subscribed to GRASSLIST@baylor.edu.
How do I unsubscribe from that list?
Thank you.
Maybe you can clarify some questions...
If I unsuscribe from the baylor GRASSLIST will I be able to see messages posted to it? I mean, will I lost all the post of the users that are in late with changing?
What is the procedure you suggest to do? Just unuscribe from old maillist and subscribe to the new one?
Markus Neteler wrote:
Dear subscribers,
listproc@baylor.edu
user mailing list - this won't work. You have to use the listproc@baylor.edu email address as indicated above.
Hello,
Thank you.
grassuser mailing list
grassuser@grass.itc.it
Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
late with changing?
No, because I have subscribed the old list as "user" in the new
list (some years ago). This is how the archive was created.
Nothing should get lost.
Nearly:
- I have already subscribed all users to the new list (you posted
  in this moment to the new list which only subscribers can do)
    -> nothing to do
- you have to unsubscribe yourself from the old list, because I
  don't have permissions to do so.
    -> to do for you
The transition should be really smooth. All emails arrive, and you
were already subscribed to the new list by me. The only thing which
*you* have to do is to unsubscribe from the old list (and use the
new address <grassuser@grass.itc.it> apparently). Mails which are
still sent to the old address will be distributed through the
new list as well so that you will receive also those.
Hope this clarifies it,
>Dear subscribers,
> listproc@baylor.edu
>Markus
>>Hello,
>>Thank you.
>_______________________________________________
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
