[GRASS-user] How update vector layers?
The great problem in create a new map is that there is a database with rules
of integrity. If the table sugarcane is linked to other table by
primary/foreign keys i can’t simply delete it and put the new table in your
place. This is my problem. I have to mantain the table sugarcane and keep
updating it, when necessary.
thyberio
Thybério,
as Markus said, you cannot proceed this way because your output map is
already involved in the patch process. So using the -a option, you must
not include the target map.
Try : v.patch -a -e --overwrite input=sugarcane_update output=sugarcane
To work safely regarding your database structure, I would suggest you to
test on a copy of map sugarcane (again : particularly be sure of
non-overlaping cat values...)
Keep trying, you'll get it !
Vincent
rules
primary/foreign keys i can't simply delete it and put the new table in
your
keep
thyberio
grass-user mailing list
grass-user@lists.osgeo.org
Now it works!!! :smiley:
The problem was that: the map “sugarcane” can´t be added to the input parameter, only the update map. A litlle detail, but that give me headache!
Markus and Vincent, because guys like you newbies avoid the temptation (and costs) of facilities of the ARCGI$.
Congratulations!
thyberio
2009/3/8 Vincent Bain <bain@toraval.fr>
Thybério,
non-overlaping cat values…)
Keep trying, you’ll get it !
Vincent
rules
your
keep
thyberio
