Hello Grass User,
Any one can solve me the problem like-“How we can Import data using XLS file rather csv and how we can build polygon by two or more line-arc”.
Swapan Ghosh
Hello Grass User,
Swapan Ghosh
2012/2/29 SWAPAN GHOSH <swap.ghsh@gmail.com>:
Any one can solve me the problem like-"How we can Import data using XLS file
rather csv"
try `v.in.ogr` with the most recent version of GDAL/OGR (ensure that
XLS driver is built [1]).
v.in.ogr -f
Available OGR Drivers:
XLS (ro): XLS
Martin
[1] http://gdal.org/ogr/drv_xls.html
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
On Wed, Feb 29, 2012 at 6:44 AM, SWAPAN GHOSH <swap.ghsh@gmail.com> wrote:
Hello Grass User,
rather csv and
(see Martin's answer)
how we can build polygon by two or more line-arc".
You need to convert the lines into "boundary" type with v.type
and then add a centroid with v.centroid. See also
http://grass.osgeo.org/wiki/Convert_vector_types
I am not satisfied with the answer with respect to the problem as " how we can build polygon by two or more line-arc ". The way said I am trying before that and I need more appropriate practical way not just concept.
Swapan Ghosh
Hello Grass User,
rather csv and(see Martin’s answer)
You need to convert the lines into “boundary” type with v.type
and then add a centroid with v.centroid. See alsohttp://grass.osgeo.org/wiki/Convert_vector_types
Sorry about this.
Then consider to be a bit more detailed with your question...
