[GRASS-user] howto change arrtibute column name
I have imported successfully a large dataset to grass. After the import
the attribute columns are named like this: dbl_1 dbl_2......
I would like to change this names for something more friendly. I tried
some dbf editors but the allow only to change values but not the
database structure.
Any ideas?
Regards
Zbigniew
Zbigniew Perski wrote:
database structure.
Any ideas?
OO.org let's you edit column names.
If more than 64k row use db.execute to copy all the attributes from
column 'oryg_name' in the input table to a column 'new_name' in the
output table, v.db.connect to change connection with tables.
Maciek
database structure.
Any ideas?
You can actually use oobase to connect to your dbf file using the dbase driver (in the launch dialog chose "connect to existing database").
Then you don't have any problems with row number limits ...
Moritz
Maciek
grassuser mailing list
grassuser@grass.itc.it
>>Hi,
>>database structure.
>>Any ideas?
Now it's a FAQ article :slight_smile:
http://grass.gdf-hannover.de/wiki/SQL_rename_columns
