Hi Rich
HEC-RAS will run under Wine, you will need to find, install and register MFC40.dll - there is some guidance on it on the net.
The command line version of SWMM is a 10 minute exercise to compile on Linux. The challenge would be presenting it with the correct output from GRASS. Guidance is available from the EPA website as to what the run files should look like.
I've got both (above) running under OpenSUSE.
Regards
Adam Tokelove
>> You can run HEC-RAS, 1-D flow model, freeware, only available for windows
>> (Gods bless virtual machines) and then you can use r.inund.fluv (grass
>> addon) to spread the simulation result upon the DEM. Note that in order to
>> use HEC-RAS you need measures of the river sections.
>Margherita,
> Hm-m-m. I have an old VMware guest with win98se that I can run on
>virtualbox. Don't know if the HEC series will run on that version of
>Microsoft.
>Rich
Disclaimer - http://www.aurecongroup.com/apac/disclaimer/
