[GRASS-user] hydro-flatenning process ?
Hello,
From a dem file (breaklines), i would like apply hydro-flatenning process.
Is it possible to do that with grass?
Thanks.
Regards.
Laurent.
View this message in context: http://osgeo-org.1560.x6.nabble.com/hydro-flatenning-process-tp5065095.html
I would like define an hydrologic topology on my DEM. Each cellul of my
raster should have a topologic
component. My goal is to flatten waterway areas 's values.
r.in.xyz
http://grass.osgeo.org/grass64/manuals/r.in.xyz.html
r.surf.idw
http://grass.osgeo.org/grass64/manuals/r.surf.idw.html
v.surf.bspline
http://grass.osgeo.org/grass64/manuals/v.surf.bspline.html
v.surf.rst
http://grass.osgeo.org/grass64/manuals/v.surf.rst.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/hydro-flatenning-process-tp5065095p5065707.html
Helmut Kudrnovsky wrote
r.in.xyz
r.surf.idw
v.surf.bspline
v.surf.rst
None of these, or any of GRASS's other surface interpolation tools that I'm
aware of, consider breaklines. Although a feature request was filed 4 years
ago: http://trac.osgeo.org/grass/ticket/793
You could probably generate hydro flattened surfaces separately and combine
them with the DEM manually using the raster calculator, but unfortunately I
don't think there is a one click button.
View this message in context: http://osgeo-org.1560.x6.nabble.com/hydro-flatenning-process-tp5065095p5065874.html
I'm aware of, consider breaklines. Although a feature request was filed
4 years ago: http://trac.osgeo.org/grass/ticket/793
see the v.triangle addon module,
http://grasswiki.osgeo.org/wiki/TIN_with_breaklines
ticket updated. (breaklines in v.surf.rst would still be awesome :slight_smile:
Hamish
