[GRASS-user] Hydroligics in grass
Hi Users on the list
To trace back the overland flood mechanism in (sub)urban area I’ve done some experiments in grass.
(Sub)urban areas has in general a sewer-system (combined or storm).
One of the design-parameters of a sewer is the maximal capacity of rainfall, in most cases e sewer is design
to carry off about 20mm/h rain.
In case of very heavy storm about 60 mm/h the sewer becoms full and an overland flood mechanism come into being.
I’ve a 5x5 meter grid DEM of the area.
In grass there are several modules to simulate overland flood.
  • r. terraflow
  • r.watershed
  • r.topmodel
  • r.topidx
What is the most useful module(s) in grass to simulate overland flood mechanism?
First I used the r.terraflow module the resulting accumulation map is here:
Terraflow accumulation map
Using the r.watershed module resulting streammap is here:
Watershed stream map
In both maps the red boxes are the complaints of water flood
A foto of the real situation is here
Foto
Thanks
Joop Goedbloed
I can't get to any of the pictures. r.terraflow and r.watershed are
both using lowest neighbor in eight directions to rout flow - SFD =
single flow direction and MFD is multiple flow direction.
On Fri, Dec 11, 2009 at 1:44 PM, Joop Goedbloed <jlgoedbloed@hetnet.nl> wrote:
To trace back the overland flood mechanism in (sub)urban area I've done some
I've a 5x5 meter grid DEM of the area.
* r. terraflow
* r.watershed
* r.topmodel
* r.topidx
mechanism?
Foto
Thanks
Joop Goedbloed
grass-user mailing list
grass-user@lists.osgeo.org
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
                -K. Mullis
   That's because the 192.168.0.0 IP address block is only for Class C
local networks. Similarly, 10.0.0.0 and 172.16.0.0 are Class A and B
local networks. None are addressable externally but can be reached via NAT
(Network Address Translation) that uses a single world-viewable IP address.
Rich
Another module that might be applicable is r.sim.water
http://grass.itc.it/grass65/manuals/html65_user/r.sim.water.html
Mark
* r. terraflow
* r.watershed
* r.topmodel
* r.topidx
mechanism?
Foto
Thanks
Joop Goedbloed
Stephen Sefick
                                                           \-K\. Mullis
  • r. terraflow
  • r.watershed
  • r.topmodel
  • r.topidx
Foto
For the puctures try ftp://80.61.251.86/Houtblerick/
there are the tree pictures.
