[GRASS-user] Hypsometry profile
My question is not directly associated with GRASS GIS…
I’ve generated profiles with use of r.profile command, so I have txt output file.
On basis of this file I need to prepare the hypsometry profile.
The simple one I can prepare with OpenOffice, but I need more complicated one which will prepare an output file (eps, image?) at least with horizontal and vertical scale defined by the user (me in this case).
Do you know any of such software running on Linux?
regards,
Radomir
On Thursday 07 February 2008, mort wrote:
My question is not directly associated with GRASS GIS...
I've generated profiles with use of r.profile command, so I have txt output
file.
regards,
Radomir
R comes to mind:
http://cran.r-project.org/
an example:
http://casoilresource.lawr.ucdavis.edu/drupal/node/375
Dylan Beaudette
Soil Resource Laboratory
University of California at Davis
530.754.7341
output file.
in this case).
You could try with many softwares....
ETOPO2 dataset:
g.region rast=etopo2
r.transect -g map=etopo2 line=-180,0,90,360 > equator_elev.dat
All of the following should allow nice EPS output instead of default
ugly X-window versions. (e.g. Gnuplot's X-Window stuff is very ugly but
PNG,EPS,SVG output can look very nice)
Octave (or Matlab):
$ octave
eq_elev = load('equator_elev.dat');
figure(1)
plot(eq_elev(:,1), eq_elev(:,4))
figure(2)
hist(eq_elev(:,4))
R:
$ R
eq_elev <- read.table("equator_elev.dat")
hist(eq_elev[[4]])
Gnuplot:
$ gnuplot
gnuplot> set terminal postscript
gnuplot> set output 'elev.ps'
gnuplot> plot "equator_elev.dat" using 1:4 title 'Elevation'
(check if your version of gnuplot supports 'set style data histogram')
Python: (maybe someone else can help here)
plot()
with Matplotlib (PyLab)
hist(x, 100) # use 100 bins
etc.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> txt output file.
> in this case).
Hamish:
ETOPO2 dataset:
but
Octave (or Matlab):
$ octave
>> figure(1)
>> figure(2)
>> hist(eq_elev(:,4))
R:
$ R
> hist(eq_elev[[4]])
Gnuplot:
$ gnuplot
histogram')
[time passes .. whiz .. bang .. whirl .. replying to myself]
Matplotlib (PyLab) is a python module which is yet another software
that, like Octave, "works in a fashion not dissimilar to Matlab(tm)".
And so it's easy to get nice plots:
$ python
from pylab import *
data = load("equator_elev.dat")
# unlike ML array index starts at 0, so 4th column is 3.
hist(data[:,3], 100)
xlabel('Elevation')
ylabel('Count')
title('ETOPO2 along the Equator')
show()
Hamish
Hi list
Using v.surf.rst I get sometimes thes message “File size limit exceeded”:
g.region rast=hull res=1; v.surf.rst qpd maskmap=hull elev=dtm_1m zcolumn=z --o
Percent complete:
It works well with a resolution of 5 meters.
I guess I have enough space on the disc where my grassdatabase is. (15 GB)
IS there a posibility to tell GRASS not to limit the filesize - or to increase it?
Same problem when I use r.resamp.rst:
r.resamp.rst srtm_basic_5m ew=1 ns=1 elev=srtm_basic_1m mask=wo_07_mask
Processing all selected output files will require
537.543.028 bytes of disk space for temp files.
but
r.resamp.rst srtm_basic ew=5 ns=5 elev=srtm_basic_5m mask=wo_07_mask
880.528.752 bytes of disk space for temp files.
Temporarily changing the region to desired resolution …
Bitmap mask created
Changing back to the original region …
Percent complete:
100%
dnorm in ressegm after grid before out2= 379.474663
dnorm in mainc after grid before out1= 379.474663
dnorm in mainc after grid before out2= 379.474663
Temporarily changing the region to desired resolution…
Changing the region back to initial…
r.resamp.rst complete.
In 2nd case the temp space is larger than in first ???
(880.528.752 ↔ 537.543.028 bytes)
Thank you
cheers
on shantih
Philipp
Hi again
Before I ask more questions which maybe already were asked before - how can I search the archives of the grass-user-list?
cheers
Philipp
On 08/02/08 10:52, Philipp Steigenberger wrote:
Hi again
google: "grass-user keywords"
http://www.nabble.com/GRASS-f1200.html
http://news.gmane.org/gmane.comp.gis.grass.user
Moritz
On Feb 8, 2008 10:52 AM, Philipp Steigenberger <userlist@online.de> wrote:
Hi again
Despite the nablle and gmane archives, the main search page is
http://grass.osgeo.org/searchgrass.php
I have now added a provisional mailing list search based on Google.
Additionally, I have opened a ticket to OSGeo-SAC to
add "htdig" on the new master site:
http://trac.osgeo.org/osgeo/ticket/203
Hope this gets installed soon to have back a decent search engine.
It would be nice to have a "sort by date" option as like in gmane and
nabble
On Feb 8, 2008 2:24 PM, Nikos Alexandris
nabble
I could not figure out how to tell Google to do that. At least there
is now restricted time period searching possible:
As soon as there is a bit of time I'll install htdig on the server.
Looks good.
It would also be nice to figure out how to get google to search all
mailing lists at once (excluding robotic -QA and -commit).
Hamish
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
On Feb 8, 2008 10:47 AM, Philipp Steigenberger <userlist@online.de> wrote:
Hi list
Using v.surf.rst I get sometimes thes message "File size limit exceeded":
--o
Percent complete:
Please report
g.region rast=hull res=1 -p
Or you have exceeded the 2Gb file size limit of a 32-bit OS (post
g.region output from
above to check this), but it is possible that you have a file size
limit set in your shell.
I read something about limits defined in:
/etc/security/limits.conf
