[GRASS-user] i.atcorr (6S): implementing new airborne hyperspectral sensor
Hello dear GRASS Users,
I would like to carry out an atmospheric correction of some AISA Eagle data with 6S. It’s a hyperspectral, airborne sensor. There are 60 bands in the range from 405 to 951 nm (about a 9,2 nm - step).
So my question(s)… Is it possible to implement a new hyperspectral, airborne sensors in i.atcorr? I know there is already a hyperspectral satellite sensor included.
If it is possible, how much time will be roughly consumed to undertake this task? Days, weeks or months?
Furthermore, I’ve already read the i.atcorr README to “add new band filters” (http://trac.osgeo.org/grass/browser/grass/trunk/imagery/i.atcorr/README), but I’m an absolute beginner, so unfortunately I wasn’t able to figure out how to create the needed filter function.
Can somebody point me in the right direction please?
Thanks for your effords!
Alexander K.
Hi Alexander,
with 6S. It's a hyperspectral, airborne sensor. There are 60 bands in the
So my question(s)... Is it possible to implement a new hyperspectral,
I'm not quite sure if *airborne* sensors can be added to 6S.
Did you find any research papers on that?
Rather days (hours?) that anything else *if* it is possible.
Furthermore, I've already read the i.atcorr README to "add new band filters"
but I'm an absolute beginner, so unfortunately I wasn't able to figure out
In general:
You need to obtain the spectral curves of each band from the sensor provider.
This is then turned into a simple style formatted kind of ASCII table
and added to the software.
Essentially you need to write out the various spectral curves as CSV
table. See for example
https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/imagery/i.atcorr/sensors_csv
Then use the create_iwave.py script which is in the parent directory
to turn the tables into code to be added to the iwave.cpp file, then
add the sensor to the sensor list and manual (see the README) and
recompile.
hope this helps
