I'm once again in trouble with i.atcorr in GRASS6.5.svn.
I notice that my output reflectance images are strange: there are some areas
that are really bright and other that are really dark. Both seem to match
with my DEM raster.
Could there be problems with negative values in DEM?? I'm in a coastal area
and there are some real altitude negative values.
If you need, this is my r.info of the DEM.
http://osgeo-org.1803224.n2.nabble.com/file/n6374760/rinfodemsrtm.txt
rinfodemsrtm.txt
Hope that someone could help me..
Thank you!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-negative-DEM-tp6374760p6374760.html
On Tue, May 17, 2011 at 9:22 PM, Elena Mezzini <elena.mezzini@gmail.com> wrote:
with my DEM raster.
i.atcorr (the 6S code it is using to be exact) should treat negative
elevation values as elevation = 0. It is debatable if this is correct,
but in theory i.atcorr should behave accordingly. Actually, I am not
sure about it's behaviour for negative elevation values...
You could set all negative elevation values to zero, run i.atcorr
again and compare the results to the i.atcorr results using the
original DEM. If there are any differences that do not make sense,
please fill in a bug ticket.
Markus M
areas
with my DEM raster.
area
Ok, how can I do it?
run i.atcorr again and compare the results to the i.atcorr results using the
Markus M
Thank you!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-negative-DEM-tp6374760p6374961.html
On Tue, May 17, 2011 at 10:08 PM, Elena Mezzini <elena.mezzini@gmail.com> wrote:
areas
with my DEM raster.
area
replace my_elevation with the name of your elevation map:
g.region rast=my_elevation
r.mapcalc "elevation_positive = if(my_elevation < 0, 0, <my_elevation>)"
areas
with my DEM raster.
area
g.region rast=dem_sross_srtm
r.mapcalc "dem_sross_srtm_pos = if(dem_sross_srtm < 0, 0, <dem_sross_srtm>)"
Syntax error!
As you know I'm not a programmer... where is the error?
Thank you once again
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-negative-DEM-tp6374760p6375046.html
On Tue, May 17, 2011 at 10:34 PM, Elena Mezzini <elena.mezzini@gmail.com> wrote:
areas
with my DEM raster.
area
Syntax error!
remove the <> (actually I forgot to remove them in the template...):
r.mapcalc "dem_sross_srtm_pos = if(dem_sross_srtm < 0, 0, dem_sross_srtm)"
areas
match
with my DEM raster.
area
<dem_sross_srtm>)"
Syntax error!
Elena
Found:
Sorry!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-negative-DEM-tp6374760p6375058.html
areas
match
with my DEM raster.
area
<dem_sross_srtm>)"
Syntax error!
Elena
Found:
Sorry!
Elena
No differences between negative and positive values...
I don't know what could be the problem...
Thank you for your helpfulness!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-negative-DEM-tp6374760p6375143.html
On Tue, May 17, 2011 at 10:57 PM, Elena Mezzini <elena.mezzini@gmail.com> wrote:
areas
match
with my DEM raster.
area
What do you mean precisely?
2011/5/24 Markus Neteler <neteler@osgeo.org>
I’m once again in trouble with i.atcorr in GRASS6.5.svn.
areas
match
with my DEM raster.
Could there be problems with negative values in DEM?? I’m in a coastal
area
r.mapcalc “dem_sross_srtm_pos = if(dem_sross_srtm < 0, 0, dem_sross_srtm)”
No differences between negative and positive values…
I mean that i.atcorr automatically considers negative values equal to 0. So the results of i.atcorr with negative values or with negative values made equal to zero are the same.
So I still have problem with all the bands of landsat probably due to DEM.
Elena
