Hi all
I’m still trying to run i.atcorr with ASTER images, but without success. It doesn’t matter how I set the parameters, the result is always an empty raster. The range and rescale parameters don’t change anything in the result.
Perhaps some dev can look into the code to see if anything changed?
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
On Thu, Mar 24, 2016 at 12:05 AM, Carlos Grohmann
<carlos.grohmann@gmail.com> wrote:
Hi all
I'm still trying to run i.atcorr with ASTER images, but without success. It
doesn't matter how I set the parameters, the result is always an empty
raster. The range and rescale parameters don't change anything in the
result.
The code is fairly complex...
The latest changes you can see here:
https://trac.osgeo.org/grass/log/grass/branches/releasebranch_7_0/imagery/i.atcorr
I wonder if this library would work for you
https://py6s.readthedocs.org
(could become a wrapper then)
best,
Markus Neteler
http://www.mundialis.de
http://courses.neteler.org/blog/
