Hi again,
Even with constant spectral conditions and values for filter function from Sentinel-2, all combinations of input band ranges result in empty maps.
Constant spectral conditions and values for filter function from Landsat7 however, give results in the expected scale (0-255) regardless input image and value ranges...
Shall I open a ticket?
Any idea/chance to get this new feature in G7.4 to work...?
Any pointer/help would be very much appreciated!
Stefan
-----Original Message-----
Sent: tirsdag 19. desember 2017 10.56
To: Stefan Blumentrath <Stefan.Blumentrath@nina.no>; Moritz Lennert <mlennert@club.worldonline.be>; Žofie Cimburová <zoficimburova@gmail.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Subject: RE: [GRASS-user] i.atcorr with Sentinel2
Hi again,
Still trying to track down the issue...
I now ran i.atcorr with constant spectral condition and manually defined "wl inf" and "wl sup".
First I got those values for Sentinel-2 band 2:
* spectral condition *
* sentinel2a blue b2 *
* value of filter function : *
* wl inf= 0.300 mic wl sup= 2.600 mic *
Then for Landsat 7 band 4 (that was known to give results):
* etm+ 4 *
* wl inf= 0.740 mic wl sup= 0.913 mic *
If I then feed those values into a filter function for constant spectral conditions, and again the Sentinel-2 values:
* constant *
lead to empty maps, while Landsat7 values:
* constant *
work fine (with all other settings being equal).
That makes me suspect that the values of the Sentinel-2 filter function are actually causing the issue here...
I am currently testing all thinkable combinations of input band ranges to see if any of them works with wl inf=0.300 mic and wl sup=2.600 mic and will report back from that exercise.
Meanwhile, can anyone confirm that i.atcorr in GRASS 7.4.0RC1 actually works with Sentinel-2 data?
Stefan
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Stefan Blumentrath
Sent: tirsdag 19. desember 2017 08.45
To: Moritz Lennert <mlennert@club.worldonline.be>; Žofie Cimburová <zoficimburova@gmail.com>
Subject: Re: [GRASS-user] i.atcorr with Sentinel2
Hi again,
A little update on the problem:
Now I ran i.atcorr with all possible band values for Sentinel-2 in the 6s parameters (166-178) with input maps ranges scaled to 0-1, 0-255, 0-10000 All runs resulted in completely empty maps!
Any ideas?
Thanks for helping in advance!
Kind regards,
Stefan
From: Moritz Lennert [mailto:mlennert@club.worldonline.be]
Sent: mandag 18. desember 2017 16.58
To: Stefan Blumentrath <Stefan.Blumentrath@nina.no>; Žofie Cimburová <zoficimburova@gmail.com>
On 18/12/17 16:35, Stefan Blumentrath wrote:
Hi Moritz,
Thanks for helping with troubleshooting!
QUANTIFICATION_VALUE is 10000, Thus dividing with it gives a maximum value of 2.8...
Any idea how to figure out if it is 12 or 16 bit image. It is directly downloaded from ESA...
Check which proportion of the image is > 1. AFAIR (which is a bit limited), you might have reflectances above 1 in saturated pixels. I just checked on a random image and I also have some pixels above 1, but only 0.25% of the pixels:
GRASS 7.5.svn (UTM32N):/data/home/mlennert > r.mapcalc "test = if(b04_refl>1,1,0)"
100%
GRASS 7.5.svn (UTM32N):/data/home/mlennert > r.stats -cp test
100%
0 120259106 99.75%
1 301294 0.25%
And all the pixels with value 1 are in clouded areas.
Moritz
Stefan
Of Moritz Lennert
Sent: mandag 18. desember 2017 16.26
To: Žofie Cimburová <zoficimburova@gmail.com>
On 18/12/17 16:13, Žofie Cimburová wrote:
Dear Moritz,
According to
https://earth.esa.int/web/sentinel/user-guides/sentinel-2-msi/product
- types , the L1C product I am using already is in top of atmosphere
reflectance, so this should not be the problem (?).
I tried running i.atcorr both with and without the -r flag.
Reflectance is the percentage of light that is reflected either from
the top of the atmosphere or from the surface. Reflectance values
should thus be real values between 0 and 1. Your data have
Range of data: min = 1 max = 28000
This means that they are expressed in digital (integer) numbers. Try transforming these DN into real numbers. IIRC, in the metadata, you have a variable QUANTIFICATION_VALUE. Divide your pixel values by that value to get real TOA reflectance values.
AFAIK, it also depends on whether you directly imported the original 12-bit file, or possibly a modified, e.g. 16-bit, version.
Moritz
On Mon, Dec 18, 2017 at 3:35 PM, Moritz Lennert
<mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>> wrote:
On 18/12/17 13:14, Žofie Cimburová wrote:
Now the 6S parameters are complete, but the output map contains
only NULLs, no matter what combinations of input parameters and
flags I use. Have anyone encountered the same issue? (Info
below.)
In the i.atcorr man page it says:
"If flag -r is used, the input raster data are treated as
reflectance. Otherwise, the input raster data are treated as
radiance values"
IIUC, your data is still in DN. You might want to try to transform
this into radiance values before sending it into i.atcorr.
Moritz
Thanks again.
Zofie
Version:
g.version -g
version=7.4.0RC1
date=2017
revision=exported
build_date=2017-11-18
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
Region:
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
north: 6653695
south: 6643685
west: 256495
east: 266505
nsres: 10
ewres: 10
rows: 1001
cols: 1001
cells: 1002001
Input data: Sentinel2 L1C product B02 (tried with B01 too)
r.info <http://r.info> <http://r.info>
map=test_B02@p_Sentinel4Nature_S2_Oslo
| Map: test_B02@p_Sentinel4Nat Date: Wed Dec 6
12:06:39 2017
| Mapset: p_Sentinel4Nature_S2_Oslo Login of Creator:
stefan.blumentr
| DataBase: /data/grass
| Title:
S2A_OPER_PRD_MSIL1C_PDMC_20160907T044118_R008_V20160905T104022_2
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 1001
| Columns: 1001
| Total Cells: 1002001
| Projection: UTM (zone 33)
| N: 6653695 S: 6643685 Res: 10
| E: 266505 W: 256495 Res: 10
| Data Description:
| generated by r.in.gdal
6s file:
25- geometrical conditions=Sentinel-2A
9 5 10.6728 10.73413 59.90647- month day hh.ddd longitude latitude
4 - atmospheric model=subarctic summer
3- aerosol model=urban
50- visibility [km] (aerosol model concentration) (this is
estimated, I also tried with AOD specified)
-0.055- mean target elevation above sea level [km]
-1000- sensor height
166- Sentinel2A Blue band B2 (440nm - 535nm)
Command:
i.atcorr input=test_B02@p_Sentinel4Nature_S2_Oslo range=1,28000
elevation=dem_10m_25833@p_Sentinel4Nature_S2_Oslo
parameters=/home/NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt
<http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>
<http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>>
output=test_B02_atcorr
>Atmospheric correction...
>Atmospheric correction complete.
(I am not sure about the range parameter, tried with 0,255 too.
The DEM contains no NULLs. Also tried running with -r and -a
flags.)
Output:
map=test_B02_atcorr@p_Sentinel4Nature_S2_Oslo
| Map: test_B02_atcorr@p_Sentinel4N Date: Mon Dec 18
13:10:14 2017
zofie.cimburova
| Title: test_B02_atcorr2
| Timestamp: none
| Data Type: FCELL
| Rows: 1001
| Columns: 1001
| Range of data: min = -nan max = -nan
| Data Description:
| generated by i.atcorr
| Comments:
| i.atcorr input="test_B02@p_Sentinel4Nature_S2_Oslo"
range=1,28\
| 000 elevation="dem_10m_25833@p_Sentinel4Nature_S2_Oslo"
para\
meters="/home/NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt <http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>
<http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>>" o\
| utput="test_B02_atcorr2" rescale=0,255
On Fri, Dec 15, 2017 at 5:12 PM, Žofie Cimburová
<zoficimburova@gmail.com <mailto:zoficimburova@gmail.com>
<mailto:zoficimburova@gmail.com>>> wrote:
Dear Markus,
thanks for your reply, this is exactly what I need to know!
Best, Zofie
On Fri, Dec 15, 2017 at 5:09 PM, Markus Neteler
<neteler@osgeo.org <mailto:neteler@osgeo.org>
<mailto:neteler@osgeo.org>> wrote:
On Dec 15, 2017 3:54 PM, "Žofie Cimburová"
<mailto:zoficimburova@gmail.com> <mailto:zoficimburova@gmail.com
> Dear all,
> I am trying to use i.atcorr (GRASS 7.4) to apply
atmospheric corrections for Sentinel 2 data. The documentation
provides a great help, but there are two points I am not sure
about - >
> - I don't need the atmospheric correction to be
applied to the whole scene, so I only imported a small clip of
the scene to GRASS. What longitude and latitude shall I then
specify in the 6S parameters?
I'd use the center coordinates of the clipped area.
> Or is it necessary to apply the corrections to the
entire scene?
No since it is a pixel based algorithm.
> - How can I estimate the value of visibility (aerosol
model concentration)?
There are AERONET data online somewhere which might be
the best
choice.
grass-user mailing list
grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
<https://lists.osgeo.org/mailman/listinfo/grass-user>
