[GRASS-user] i.class with i.maxlik
i,
im a french guy so excuse my english.
i try to do a supervised classification with grass but i have an error when
use i.maxlik
with i.class i create a sigfile. i.maxlik don't find this file...
howewer the file appear in the subgroup folder
have you some exemple with i.class and i.maxlik?
do you think its bug?
thanks
View this message in context: http://n2.nabble.com/i-class-with-i-maxlik-tp3880348p3880348.html
On Fri, Oct 23, 2009 at 7:07 PM, nawak <nada81@laposte.net> wrote:
i,
use i.maxlik
I can confirm that it gives such a message (6.4.svn).
Right.
The problem is that i.maxlik apparently no longer writes the image
statistics. It used to work.
What I get (North Carolina example):
i.class lsat7_2002_20 group=lsat7_2002 subgroup=lsat7_2002 outsig=testsig
GRASS 6.4.0svn (nc_spm_08):~/grassdata/nc_spm_08/neteler/group/lsat7_2002/subgroup/lsat7_2002/sig/
cat testsig
#water
525
#terrain
897
-> no statistics!
Now this would follow but is useless due to the broken sigfile:
i.maxlik group=lsat7_2002 subgroup=lsat7_2002 sig=ciao class=class
Its error message is unhelpful.
In the i.class ChangeLog I don't see relevant changes, so it must be
a bug in I_write_signatures() perhaps?
