[GRASS-user] I could not use v.in.ogr
hello
I could not use v.in.ogr.
I have a postgis table
at postgresql side:
bzk2=> \d hey_yuk1
           Table "public.hey_yuk1"
    Column | Type | Modifiers
cat | integer | not null
hey_no | integer |
p_cat | integer |
yuk | double precision |
wkb_geometry | geometry |
Indexes:
    "hey_yuk1_pkey" PRIMARY KEY, btree (cat)
    "ix1" gist (wkb_geometry)
when I wanted to import it to grass, I got:
v.in.ogr dsn="PG:host=localhost dbname=bzk2 user=postgres" layer=hey_yuk1 output=gheyno115 type=point
ERROR: Layer <hey_yuk1> not available
But it actually exists and I can open it with QGIS
what might be wrong ?
the fact that it was created from another spatial table causes a problem ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
El Tuesday 02 October 2007 12:33:20 temiz escribió:
hello
at postgresql side:
bzk2=> \d hey_yuk1
hey_no | integer |
p_cat | integer |
Indexes:
regards
The table you listed is named "public.hey_yuk1", perhaps adding "public" to
the table name could help.
Lic. Gustavo Martínez
Gestión de Pesquerías
Sub Secretaría de Pesca de la Nación
Paseo Colón 982, Anexo Jardín Pesca
Tel: (54) 11 43492165
Buenos Aires, República Argentina
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
