Hi all!
I am confused about the utility of r.patch and i.group w.r.t. image classification.
In ERDAS for supervised classification layer stacking can be done followed by classification.
A way to layer stack in GRASS would be r.patch (since layers are more than 3, I can’t use r.composite). But for classifying in GRASS since i.group has to be used, can I use i.group to do layer stacking instead of using r.patch and then classify?
Thanks and regards,
Chethan S.
On Tue, May 17, 2011 at 4:01 PM, Chethan S. <chethanuniversal@gmail.com> wrote:
Hi all!
classification.
by classification.
3, I can't use r.composite). But for classifying in GRASS since i.group has
and then classify?
If you want to mosaik (compose spatially *adjacent* maps), then use r.patch.
If you want to vertically merge images in order to close holes, use r.patch.
If you want to vertically merge images in order to make a RGB composite
or HIS composite, use r.composite etc
If you want to *logically* combine a stack of maps in a group (that's only
targeting the metadata essentially), use i.group.
Most i.* commands expect a group to be defined in order to easily tell them
which images to be analysed. That's all that i.group does.
Hope this helps
