[GRASS-user] i.his.rgb issue
hi
i've an error using the last cvs version on the command
  "i.his.rgb"
i tried the same command using grass6.2.1 and an old (3 week) 6.3 cvs without problem.
but using the last cvs (downloaded yestrday)
it give me :
  "unable to find imput cell map <red>"
but the "red" map is an output ... see the screenshot : on the right the 6.3cvs, on the left 6.2 :
http://img206.imageshack.us/img206/9130/immagine14ib2.png
is this a common problem ... or something is wrong in my last build ?
thanks,
Massimo
  "i.his.rgb"
without problem.
it give me :
Both. This is a common symptom of trying to perform a partial build
(i.e. without running "make clean") after updating from CVS.
Always run "make clean" before updating from CVS.
> "i.his.rgb"
> without problem.
> it give me :
It was actually a minor mistake I made. I talked to him last night on
IRC (GRASS GIS) and promptly fixed it in CVS.
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
