[GRASS-user] i.histo.match error
Hello all,
Been trying to run i.histo.match but keep getting this error:
  File "i.histo.match.py", line 223, in <module>
    sys.exit(main())
  File "i.histo.match.py", line 89, in main
    curs.execute(query_create)
sqlite3.OperationalError: unknown database tnormalized
All help is appreciated...
(grass7-win7 64b)
luis
Luís Mário Ribeiro wrote:
Hello all,
Hi!
    sys.exit(main())
(grass7-win7 64b)
Would you mind posting the exact command you are trying to execute?
Thanks, Nikos
Hi Nikos, all
Been using histo.match thru the GUI. The command that appears in the output
window is (in this example just 3 images):
i.histo.match
input=normalized.LT52030312007052MPS00_tr_reflec3_int@histomatch,normalized.
LT52030312007052MPS00_tr_reflec4_int@histomatch,normalized.LT52030312007180M
PS00_tr_reflec3_int@histomatch max=1000
best regards
luis
-----Mensagem original-----
De: grass-user-bounces@lists.osgeo.org
[mailto:grass-user-bounces@lists.osgeo.org] Em nome de Nikos Alexandris
Enviada: terça-feira, 5 de Março de 2013 17:09
Para: grass-user@lists.osgeo.org
Assunto: Re: [GRASS-user] i.histo.match error
Hello all,
Hi!
    sys.exit(main())
(grass7-win7 64b)
Thanks, Nikos
grass-user mailing list
i.histo.match
M PS00_tr_reflec3_int@histomatch max=1000
I guess (not sure though) it is the same error once pointed to me by Luca
Delucchi: the "." in the input raster map names is not allowed :-(.
You need to rename them... Maybe a quick test first to be sure. Shrink your
region and test. Be sure you have beforehand a MASK or else which you use to
set the computational region. Or, export your current working region in a
vector map? (<-- v.in.region).
Hope it works, Nikos
[>]Good morning and thanks... Will try changing the "." (which was added by
Grass when performing i.topo.corr).
Best regards, luis
output window is (in this example just 3 images):
i.histo.match
07180 M PS00_tr_reflec3_int@histomatch max=1000
your region and test. Be sure you have beforehand a MASK or else which you
use to set the computational region. Or, export your current working region
in a vector map? (<-- v.in.region).
Hello list,
Changed the names of 2 files to not have any "." and rerun histo.match. A
different error showed.
I copy below the output window contents. It refers to an error in " r.stats"
(ERROR: Sorry, <fs> is not a valid parameter)
Does anyone know what I'm doing wrong?
_________
(Wed Mar 06 10:12:17 2013)
i.histo.match --overwrite
input=2030312007052_3@histomatch,2030322007052_3@histomatch max=1000
Description:
Generates area statistics for raster map layers.
Keywords:
raster, statistics
Usage:
r.stats [-1AacplgxrnNCi] input=name[,name,...]
[output=name]
   [separator=character] [nv=string] [nsteps=value]
[--overwrite]
   [--verbose] [--quiet]
Flags:
  -1 One cell (range) per line
  -A Print averaged values instead of intervals
  -a Print area totals
  -c Print cell counts
  -p Print APPROXIMATE percents (total percent may not be
100%)
  -l Print category labels
  -g Print grid coordinates (east and north)
  -x Print x and y (column and row)
  -r Print raw indexes of fp ranges (fp maps only)
  -n Suppress reporting of any NULLs
  -N Suppress reporting of NULLs when all values are NULL
  -C Report for cats fp ranges (fp maps only)
  -i Read fp map as integer (use map's quant rules)
--o Allow output files to overwrite existing files
--v Verbose module output
--q Quiet module output
Parameters:
      input Name of input raster map(s)
     output Name for output file (if omitted or "-" output
to stdout)
  separator Field separator
               Special characters: newline, space, comma,
tab
              default: space
         nv String representing no data cell value
              default: *
     nsteps Number of fp subranges to collect stats from
              default: 255
Description:
Keywords:
raster, statistics
Usage:
[output=name]
[--overwrite]
Flags:
100%)
Parameters:
to stdout)
tab
              default: space
              default: *
              default: 255
(Wed Mar 06 10:12:25 2013) Command finished (8 sec)
_____
[mailto:grass-user-bounces@lists.osgeo.org] Em nome de Luís Mário Ribeiro
Enviada: quarta-feira, 6 de Março de 2013 09:30
Para: 'Nikos Alexandris'
Cc: grass-user@lists.osgeo.org
Best regards, luis
i.histo.match
On Wed, Mar 6, 2013 at 11:16 AM, Luís Mário Ribeiro <luis.mario@adai.pt> wrote:
Hello list,
It seems that you need a newer version of i.histo.match, this was
fixed couple of weeks ago [1].
Anna
[1] http://trac.osgeo.org/grass/changeset/54833/grass-addons/grass7/imagery/i.histo.match/i.histo.match.py
_________
Description:
Keywords:
raster, statistics
Usage:
[output=name]
[--overwrite]
Flags:
100%)
Parameters:
to stdout)
tab
              default: space
              default: *
              default: 255
Description:
Keywords:
raster, statistics
Usage:
[output=name]
[--overwrite]
Flags:
100%)
Parameters:
to stdout)
tab
              default: space
              default: *
              default: 255
_____
Best regards, luis
i.histo.match
Thank you Ana and Nikos,
The version I have was instaled yesterday again and the error subsisted. I
found the log of the last change
(http://trac.osgeo.org/grass/changeset/54833) and manually edited my
"i.histo.match.py", changing "fs" for "separator".
All is working now but I have no idea how or why grass instaled an old
version :slight_smile:
Best regards
luis
De: Anna Kratochvílová [mailto:kratochanna@gmail.com]
Enviada: quarta-feira, 6 de Março de 2013 19:57
Para: Luís Mário Ribeiro
Cc: Nikos Alexandris; GRASS user list
wrote:
Hello list,
histo.match. A different error showed.
r.stats"
It seems that you need a newer version of i.histo.match, this was fixed
Anna
[1]
_________
Description:
Keywords:
raster, statistics
Usage:
r.stats [-1AacplgxrnNCi] input=name[,name,...] [output=name]
   [separator=character] [nv=string] [nsteps=value] [--overwrite]
Flags:
100%)
Parameters:
to stdout)
               Special characters: newline, space, comma, tab
              default: space
              default: *
              default: 255
Description:
Keywords:
raster, statistics
Usage:
Flags:
100%)
Parameters:
to stdout)
              default: space
              default: *
              default: 255
ERROR: Sorry, <fs> is not a valid parameter (Wed Mar 06 10:12:25 2013)
_____
Ribeiro
added by Grass when performing i.topo.corr).
Best regards, luis
i.histo.match
0
Luca
Shrink your region and test. Be sure you have beforehand a MASK or
else which you use to set the computational region. Or, export your
current working region in a vector map? (<-- v.in.region).
