[GRASS-user] i.in.spotvgt error
I try to import a spot-vegetation image by i.in.spotvgt, but I've an
error. The map already esists...
GRASS 6.4.0RC5 (WGS84_lat_long):~ > i.in.spotvgt --overwrite
file=/home/alfredo/archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980411_NDVI__Africa/0001/0001_NDV.HDF
rast=NDVI_map
ERROR: <NDVI_map> already exists. Aborting.
GRASS 6.4.0RC5 (WGS84_lat_long):~ > g.list rast
raster files available in mapset <ndvi_Africa>:
ndvi_19980401 ndvi_19980821
On Tue, Oct 20, 2009 at 11:15 AM, Alfredo Alessandrini
<alfreale74@gmail.com> wrote:
rast=NDVI_map
If you can make the file available, I can give it a try to find the problem.
http://www.unitus.it/dipartimenti/daf/dendro/V1KRNS10__19980411_NDVI__Africa.zip
On Fri, Nov 6, 2009 at 7:23 PM, Alfredo Alessandrini
Fixed in 6.4 and 6.5. 7 should be ok.
