[GRASS-user] i.in.spotvgt
I've imported some rasters by i.in.spotvgt..
I don't understand because the first attempt fail while the second is
ok. Any raster that I try to import, the result is the same. first
attempt=FAIL; second attempt=OK
1° ATTEMPT:
GRASS 6.2.2 (WGS84):~ > i.in.spotvgt
file=/home/alfredo/cartografia/satellite/V1KRNS10__19980521_NDVI__Europe/0001/0001_NDV.HDF
rast=19980521
Import SPOT VGT NDVI map...
A datum name wgs84 (WGS_1984) was specified without transformation parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
100%
CREATING SUPPORT FILES FOR 19980521
SETTING GREY COLOR TABLE FOR 19980521 (8bit, full range)
r.in.gdal complete.
Imported SPOT VEGETATION NDVI map <19980521>.
Remapping digital numbers to NDVI...
100%
WARNING: Your color rules do not cover the whole range of data!
        (rules -1.000000 to 1.000000 but data 79921.984000 to
        79921.984000)
Color table for [19980521] set to ndvi
Done.
2° ATTEMPT:
rast=19980521_2
100%
CREATING SUPPORT FILES FOR 19980521_2
SETTING GREY COLOR TABLE FOR 19980521_2 (8bit, full range)
r.in.gdal complete.
Imported SPOT VEGETATION NDVI map <19980521_2>.
100%
Color table for [19980521_2] set to ndvi
Done.
The problem will be caused by the usage of a pure
number filename. While GRASS generally supports
this, it would need a fix in i.in.spotvgt to avoid that
the r.mapcalc call within the script calculates nonsense...
Quick solution: Just use a letter in output name.
On Jan 19, 2008 1:00 AM, Alfredo Alessandrini <alfreale74@gmail.com> wrote:
1° ATTEMPT:
rast=19980521
100%
r.in.gdal complete.
100%
        79921.984000)
Done.
2° ATTEMPT:
rast=19980521_2
100%
r.in.gdal complete.
100%
Done.
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
http://www.caa2008.org/topi_abssession9.html
