[GRASS-user] i.landsat.acca addon installing
Sorry to insist resending this message, but I would really appreciate if someone can give me a clue to get out of this and be capable to add i.landsta.acca to GRASS
Thanks in advance,
Patrick
Dear listers,
I would like to install the add-on i.landsat.acca, and for that have carefully read the instructions at http://trac.osgeo.org/grass/browser/grass-addons/README, which states:
  • C code/Scripts, with GRASS binaries on your computer:
    compile GRASS Addons modules into your GRASS code by setting
    MODULE_TOPDIR to where to the GRASS binaries are located:
make MODULE_TOPDIR=/usr/lib/grass640/
I am working under Ubuntu hardy, with a precompiled version of GRASS 6.3.0. I have put those files in a folder:
algorithm.c description.html local_proto.h main.c Makefile tools.c
and from this folder:
pgiraudo@pgiraudo-laptop:~/GrassAddon$ sudo make MODULE_TOPDIR=/usr/lib/grass/
then I get a long list of errors (see below) and does not know at all from where to start to fix it…
Any idea about what to do ?
Patrick
[sudo] password for pgiraudo:
gcc -I/home/jachym/src/grass/grass-6.3.0/dist.i486-pc-linux-gnu/include -Wall -g -D_FILE_OFFSET_BITS=64 -O2 -DPACKAGE="“grassmods”" -I/home/jachym/src/grass/grass-6.3.0/dist.i486-pc-linux-gnu/include -o OBJ.i486-pc-linux-gnu/algorithm.o -c algorithm.c
algorithm.c:6:23: erreur: grass/gis.h : Aucun fichier ou dossier de ce type
algorithm.c:7:27: erreur: grass/glocale.h : Aucun fichier ou dossier de ce type
algorithm.c: Dans la fonction «acca_first» :
algorithm.c:220: attention : déclaration implicite de la fonction « «G_allocate_raster_buf» »
algorithm.c:220: erreur: «CELL_TYPE» undeclared (first use in this function)
algorithm.c:220: erreur: (Each undeclared identifier is reported only once
algorithm.c:220: erreur: for each function it appears in.)
algorithm.c:220: attention : assignment makes pointer from integer without a cast
algorithm.c:221: attention : déclaration implicite de la fonction « «G_open_raster_new» »
algorithm.c:222: attention : déclaration implicite de la fonction « «G_fatal_error» »
algorithm.c:222: attention : déclaration implicite de la fonction « «_» »
algorithm.c:232: attention : déclaration implicite de la fonction « «G_window_rows» »
algorithm.c:233: attention : déclaration implicite de la fonction « «G_window_cols» »
algorithm.c:239: attention : déclaration implicite de la fonction « «G_percent» »
algorithm.c:243: attention : déclaration implicite de la fonction « «G_get_d_raster_row» »
algorithm.c:252: attention : déclaration implicite de la fonction « «G_is_d_null_value» »
algorithm.c:252: erreur: «DCELL» undeclared (first use in this function)
algorithm.c:252: erreur: expected expression before «)» token
algorithm.c:257: erreur: expected expression before «)» token
algorithm.c:329: attention : déclaration implicite de la fonction « «G_set_c_null_value» »
algorithm.c:329: erreur: «CELL» undeclared (first use in this function)
algorithm.c:329: erreur: expected expression before «)» token
algorithm.c:333: erreur: expected expression before «)» token
algorithm.c:336: attention : déclaration implicite de la fonction « «G_put_raster_row» »
algorithm.c:343: attention : déclaration implicite de la fonction « «G_free» »
algorithm.c:344: attention : déclaration implicite de la fonction « «G_close_cell» »
algorithm.c: Dans la fonction «acca_second» :
algorithm.c:361: attention : déclaration implicite de la fonction « «G_find_cell2» »
algorithm.c:361: attention : assignment makes pointer from integer without a cast
algorithm.c:364: erreur: «CELL_TYPE» undeclared (first use in this function)
algorithm.c:364: attention : assignment makes pointer from integer without a cast
algorithm.c:365: attention : déclaration implicite de la fonction « «G_open_cell_old» »
algorithm.c:370: attention : assignment makes pointer from integer without a cast
algorithm.c:390: attention : déclaration implicite de la fonction « «G_get_c_raster_row» »
algorithm.c:395: attention : déclaration implicite de la fonction « «G_is_c_null_value» »
algorithm.c:395: erreur: «CELL» undeclared (first use in this function)
algorithm.c:395: erreur: expected expression before «)» token
algorithm.c:397: erreur: expected expression before «)» token
algorithm.c:401: erreur: expected expression before «)» token
algorithm.c:404: attention : parenthèses suggérées autour de && à l’intérieur de ||
algorithm.c:406: erreur: «DCELL» undeclared (first use in this function)
algorithm.c:406: erreur: expected expression before «)» token
algorithm.c:409: erreur: expected expression before «)» token
algorithm.c:414: erreur: expected expression before «)» token
algorithm.c:416: erreur: expected expression before «)» token
algorithm.c:422: attention : parenthèses suggérées autour de && à l’intérieur de ||
algorithm.c:424: erreur: expected expression before «)» token
algorithm.c:427: erreur: expected expression before «)» token
algorithm.c:444: attention : déclaration implicite de la fonction « «G_remove» »
algorithm.c:450: attention : déclaration implicite de la fonction « «G_rename» »
algorithm.c:353: attention : unused variable «i»
make: *** [OBJ.i486-pc-linux-gnu/algorithm.o] Erreur 1
Patrick,
does /usr/lib/grass/
contain an include/ directory with e.g. the file
grass/gis.h
? If not, perhaps a grass63-devel package is needed or the
includes are not packaged at all.
In any case, please consider to use 6.4.0RC3 instead as it
contains many fixes.
2009/4/11 Patrick Giraudoux <patrick.giraudoux@univ-fcomte.fr>:
Thanks in advance,
Patrick
Dear listers,
* C code/Scripts, with GRASS binaries on your computer:
where to start to fix it...
Patrick
-Wall -g -D_FILE_OFFSET_BITS=64 -O2 -DPACKAGE=\""grassmods"\"
type
cast
«G_fatal_error» »
«G_window_rows» »
«G_window_cols» »
«G_percent» »
«G_close_cell» »
«G_find_cell2» »
cast
cast
«G_open_cell_old» »
cast
l'intérieur de ||
l'intérieur de ||
«G_remove» »
«G_rename» »
grass-user mailing list
grass-user@lists.osgeo.org
Markus Neteler a écrit :
Patrick,
grass/gis.h
Actually yes, /usr/lib/grass contains a file grass/gis.h as well as many others like glocal.h, etc…
Suppose I must move and compile grass 6.4ORC3 now…
Patrick
Patrick,
grass/gis.h
Actually yes, /usr/lib/grass contains an include/ directory with grass/gis.h as well as many others like glocal.h, etc…
Patrick
Patrick,
ha - I found it :slight_smile:
See the difference? Obviously you need to use
make MODULE_TOPDIR=/usr/lib/grass630/
Then it may work. Essentially, define the right path :slight_smile:
Patrick,
ha - I found it :)
2009/4/11 Patrick Giraudoux [<patrick.giraudoux@univ-fcomte.fr>](mailto:patrick.giraudoux@univ-fcomte.fr):
Then it may work. Essentially, define the right path :)
Unfortunalety not… I have a path which is
Unfortunalety not... I have a path which is
/usr/lib/grass, with include/ and all the necessary files in it,
ok
But when the command is make MODULE_TOPDIR=/usr/lib/grass/ (which does
exist), it finds something somewhere but screw up when looking for
grass/gis.h or grass/glocale.h (which do exist in include/grass/)
pgiraudo@pgiraudo-laptop:~/GrassAddon$ make MODULE_TOPDIR=/usr/lib/grass/
that's no good I guess since the wrong path is hardcoded apparently.
So you need to enter
/usr/lib/grass/include/Make
and edit Platform.make and maybe other files there to reflect that stuff is in
/usr/lib/grass/ . These files are ASCII files, so easy to modify.
PS: Perhaps the 6.4.x version is packaged correctly?
I have just moved to installing grass-6.4.0RC3
1/ creating a folder grass643 in my home directory
2/ downloading and decompressing grass-6.4.0RC3.tar.gz
3/ from within ~/grass643/grass-6.4.0RC/
    ./configure (and getting things finally OK)
    make
    make install
4/ and then the nightmare: the call
     grass64
starts and works well as expected
BUT I cannot find any path on my computer leading to /usr/lib/grass64 or something else of this kind, neither a path /usr/lib/grass64/etc/Init.sh where I can parametrized some variables, etc...
locate grass64 leads nowhere (cannot find it)
In brief, I cannot find out where the operating file architecture of grass64 has been installed !!!
Any idea about what has happened?
Patrick
make
make install
grass64
Excellent. First step taken.
If you didn't change the --prefix in configure, then it is in
/usr/local/lib/grass64
Unless the "updatedb" cronjob isn't run, locate is not yet up to date.
The default is /usr/local/
Hope this helps,
  make
  make install
   grass64
Hope this helps,
Great. Really sorry to disturb you and the list with troubles obviously coming from my incomplete knowledge about Ubuntu basics !!!
We have got a step further indeed. The directories grass and Make are in /usr/local/grass-6.4.0RC3/include/ and nothing corresponding is in /usr/local/grass-6.4.0RC3/lib/
With
make MODULE_TOPDIR=/usr/local/grass-6.4.0RC3/
it does much more than before, but still incomplete (see messages below).
As a result the command i.landsat.acca is still not recognized within grass64 (aaaargh):
GRASS 6.4.0RC3 (FrancheComteLIIe_MF):~ > i.landsat.acca
bash: i.landsat.acca : commande introuvable
command and result of make MODULE_TOPDIR=/usr/local/grass-6.4.0RC3/
pgiraudo@pgiraudo-laptop:~/GrassAddon$ make MODULE_TOPDIR=/usr/local/grass-6.4.0RC3/
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/include -g -Wall -DPACKAGE="“grassmods”" -I/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/algorithm.o -c algorithm.c
gcc -I/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/include -g -Wall -DPACKAGE="“grassmods”" -I/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: Dans la fonction «main» :
main.c:98: attention : unused variable «p»
gcc -I/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/include -g -Wall -DPACKAGE="“grassmods”" -I/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/tools.o -c tools.c
tools.c: Dans la fonction «mean» :
tools.c:43: attention : unused variable «value»
gcc -L/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/lib -Wl,–export-dynamic -Wl,-rpath-link,/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/lib -o /home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin/i.landsat.acca OBJ.i686-pc-linux-gnu/algorithm.o OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/tools.o -lgrass_gis -lgrass_datetime -lz -lm -lz
make htmlcmd
make[1]: entrant dans le répertoire « /home/pgiraudo/GrassAddon »
make /home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/docs/html/i.landsat.acca.html HTMLSRC=/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin/i.landsat.acca
make[2]: entrant dans le répertoire « /home/pgiraudo/GrassAddon »
if [ “/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin/i.landsat.acca” != “” ] ; then GISRC=/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu PATH=“/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin:/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/lib:” LC_ALL=C /home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin/i.landsat.acca --html-description < /dev/null | grep -v ‘|’ > i.landsat.acca.tmp.html ; true ; fi
/usr/local/grass-6.4.0RC3//tools/mkhtml.sh i.landsat.acca ; mkdir -p /home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 i.landsat.acca.tmp.html /home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/docs/html/i.landsat.acca.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
/bin/sh: /usr/local/grass-6.4.0RC3//tools/mkhtml.sh: not found
make[2]: quittant le répertoire « /home/pgiraudo/GrassAddon »
make[1]: quittant le répertoire « /home/pgiraudo/GrassAddon »
Indeed, you have the binary:
for now, just copy it into
/usr/local/grass-6.4.0RC3/bin/
and it should work.
I have proposed a new "make install" Makefile target in the grass-dev
list which would be ideal for simplifying the installation.
With
grass64 (aaaargh):
### command and result of make MODULE_TOPDIR=/usr/local/grass-6.4.0RC3/
-g -Wall -DPACKAGE=\""grassmods"\"
l'intérieur de ||
l'intérieur de ||
-Wl,--export-dynamic
-o
make htmlcmd
make
if [
"/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin/i.landsat.acca"
!= "" ] ; then
PATH="/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin:$PATH"
LD_LIBRARY_PATH="/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/bin:/home/pgiraudo/grass643/grass-6.4.0RC3/dist.i686-pc-linux-gnu/lib:"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ;
Yahoooooooo ! Works perfectly !!!
Furthermore I have understood lots of things during the process about GRASS architecture and functionning (better late than never :wink: ).
May I suggest to insert a line describing this last “copy” step in the Readme at http://svn.osgeo.org/grass/grass-addons/README
  then copy the module created in XXXX to YYYY
Thanks a lot for all of this and your patience,
All the best,
Patrick Giraudoux
2009/4/12 Patrick Giraudoux <patrick.giraudoux@univ-fcomte.fr>:
Excellent!
And never give up :slight_smile:
May I suggest to insert a line describing this last "copy" step in the
Will perhaps do that, or just submit my proposed change which will
permits to simply do
   make MODULE_TOPDIR=/usr/lib/grass640/ install
best
