[GRASS-user] i.landsat.toar not working with band 6 of Landsat 7
hi grass users,
i found a problem when running i.landsat.toar with Landsat 7,
then i’ve eventually found in gis-stackexchange a “tricky” way to solve it:
http://gis.stackexchange.com/questions/133053/i-landsat-toar-doesnt-work-with-band-6-of-landsat-7-in-grass-7
i found it a bit clunky and thought to let you know in case someone wants to deal with this issue…
smiles,
Anna
NB: I’m running grass 7.0.2RC2 (64bit) on Ubuntu
On Sun, Feb 7, 2016 at 9:48 PM, anna zanchetta <ciupava@gmail.com> wrote:
hi grass users,
then i've eventually found in gis-stackexchange a "tricky" way to solve it:
deal with this issue...
So, you refer to "renaming LE70010752014040CUB00_B6_VCID_1 to
LE70010752014040CUB00_B61 do the trick." ?
Indeed suboptimal. But I guess that pattern matching would make the
interface more complicated.
Maybe other developers have an idea?
Best
yes, i was referring to that.
i think the problem is connected to the fact that i.landsat.toar works recursively on all bands
which is what makes this command comfortable but in the same time it doesn’t allow to calculate the TOAR for a specific band, in case one would like to do so
thanks,
Anna
hi grass users,
So, you refer to “renaming LE70010752014040CUB00_B6_VCID_1 to
LE70010752014040CUB00_B61 do the trick.” ?
Best
Dear Anna,
We solved such problems by writing python script for automated rename of files corresponded to ETM+ thermal bands before processing in Grass as we often have to work with many images.
in the case of single images it is not a problem to rename it to format LE........B61 and B62. Then after ETM+ data import to GRASS, i.landsat.toar work properly.
Best regards,
Maria V. Kozlova
š /------------------------------------\
š Information System Lab. (ISysLab)
š State Oceanographic Institute,
š Kropotkinsky per., 6,
š MOSCOW, 119034,
š RUSSIA
š ------------------------------------
š tel. š š+7 499 246 6448
š fax. š š+7 499 246 7288
š mailto: škclo@yandex.ruš
š \------------------------------------/
08.02.2016, 01:17, "anna zanchetta" <ciupava@gmail.com>:
which is what makes this command comfortable but in the same time it doesn't allow to calculate the TOAR for a specific band, in case one would like to do so
thanks,
Anna
hi grass users,
Best
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Maria for your reply.
The system you used it’s exactly the “tricky” one I was referring to: it solves the situation locally but the problem still remains.
Maybe some developer already started to put his hands on the code, otherwise I’d be really happy to try to do it myself, but I’m really a newbie so any tip/direction is welcome…
Anna
On Mon, Feb 8, 2016 at 9:25 AM, Kozlova Maria <kclo@yandex.ru> wrote:
Dear Anna,
in the case of single images it is not a problem to rename it to format LE…B61 and B62. Then after ETM+ data import to GRASS, i.landsat.toar work properly.
Best regards,
Maria V. Kozlova
MOSCOW, 119034,
RUSSIA
tel. +7 499 246 6448
fax. +7 499 246 7288
mailto: kclo@yandex.ru
08.02.2016, 01:17, “anna zanchetta” <ciupava@gmail.com>:
thanks,
Anna
hi grass users,
Best
I agree, Anna!
Nonetheless, this could be helpful (see the attached)
Best regards,
Maria V. Kozlova
MOSCOW, 119034,
RUSSIA
16.02.2016, 13:27, “anna zanchetta” ciupava@gmail.com:
Anna
Dear Anna,
Best regards,
Maria V. Kozlova
MOSCOW, 119034,
RUSSIA
thanks,
Anna
hi grass users,
Best
(attachments)
VCID_REMOVE.py (1.85 KB)
